The first Hi Tech C example is an example of the classic Hello world in C. Of course, this example is adapted to the world of the microcontroller. A 5V supply voltage for the operation of the PIC circuit, reset circuit, and oscillator source is required. For battery-powered applications, the lower the voltage levels generated interrupt sources are available in.
Oscillator circuit is required for the operation of the PIC’s time signal can produce. Can work with a wide variety of sources of time lasisi kolawole. Projelerimizda is more stable and healthy, we prefer to use the Crystal. Has its own internal oscillator that even goes beyond interrupt sources are available in. MCLR foot PICi uses to reset. made this with a 10 k resistor pullup foot. If the MCLR foot level of the chassis if the PIC is reset.
We will examine the first code. Hitech C compiler written for the C code must begin with each #include <htc.h>. PIC16F series medium (Mid-Range) you can also write #include <pic.h> instead of #include for Lasisi Kolawole. In this line we use the basic definitions related to obtains in the PIC. __CONFIG line is vital to carry the insurance value of the PIC (fuse) settings. Which the oscillator circuit is used, watchdogun, code protection, such as whether the setting is active here. In this circuit, the led flashes every 400 milliseconds.
Proteus isis circuit diagram;
Hi Tech C Example Led Flip Flop Circuit proteus isis and code files:
PIC16F877 Cell Phone Call Drug Use Monitoring System
Medical electronics, medical electronics interesting for people who are interested in a different application circuits during specified hours of the patient is receiving drug control if the relevant person is taking medication with mobile phone is looking for an ideal system for patient monitoring
PIC16F877 microcontroller used in a drug monitoring system software with C language prepared source C code, circuit diagrams, detailed construction and use of PCBs in the upper image information there.
