PIC16F877 Air RGB writing
| Updated on September 3, 2024
Hello electoronic lovers.
This breaks my spare some time to compile my application I am trying to share with you.
In this article I artificially everyone said it would offer air writing application.
I first inspiration is still working on the site I bought it from.
Writing work was done in the air, but an example of a rgb thought about doing it and I tried for quite a few it
RGB writing circuit test
havada-yazi-rgb-led-led-pov-text-120x120 smd-rgb-led-havada-yazi-leds-pov-display-circuit-120x120 leds-Rotating-led-pov-havada-yazi-display-120x120 smd-ledler-ile-havada-yazi-mikro-c-pic16f877-120x120
I took care of the software and circuit halletmesine a kind of mechanical system could not keep up . In fact, the circuit and the circuit returns to the battery with the battery run this business the easy way . I’ve watched the way the motor to the motor shaft mounted apartment that consists of rings printed circuit supply voltage via the mobile phone battery connector through the ( easy to mount and spring there is a system to chose ) power circuit moving wireless systems was to translate .
Possible cases against interruption and 1000mf10v capacitor circuit with the input voltage to ensure that fixed and I reset the PIC in . Yet Iwas able to run this system ? no. Mechanism design for everything , but I had to run in a window , but only to pack up and new application runs from the everyday bustle kursağı because of my enthusiasm I had it . But actually hooked up to the motor circuit which is great for the very slashed ! next time I’m in the circuit including transistors, resistors SMD LEDs ingredients ‘ll do it again
Isis proteus simulation of air writing applications ares pcb and code files:
Aytaç DÜRGEN
Publication date: 2010/12/24 Tags: , ,
1 Comment “PIC16F877 Air RGB writing
    RGB led show PIC12F675
    Hello Electronic lovers that I have done it again with you in this article is an applications often wanted to share. In this study, using the PIC12F675 and 74HC595 Entegere be moved sequential RGB light with a very nice splash of color emerges.
    Isis video of the application circuit and the hex code is available in the attached document. Friends who are interested let you go.
    PICmicro Connection example 74HC595
