Prepare the Microcontrollers with LCD display application provides great convenience to the various imge converter programs .bmp format photos for graphic LCD PIC assembly (ASM) as a program that converts source code and Delphi 3 code. exe file there
BMP to PIC ASM assembly (BMP2ASM)
BMP to PIC assembly utility, BMP2ASM.EXE, converts BMP files to PIC assembly code. The assembly code is then used in your program to display graphics on your LCD
FastLCD Images Icons Font Sprites designer
. bmp format pictures and have created text font formats graphic LCD for s. bas extension code can produce a picture or Prepare the text you want to register in the top menu PRINT button would click a small window LCD model would select (type of press save select) options: HD, SED, Nokia 3310 and T6963C
FastLCD – Images, Icons, Fonts and Sprites designer for Graphic LCD
Bmp2asm fastlcd Program Files
Publication date: 2008/10/26 Tags: electronics software tools
Simple 5V Regulator Circuit
Fixed 5V regulator circuit that can provide a simple. One transistor MJE3055. = The Zener voltage of the output voltage – threshold voltage transistor is according to formula.
5 V Regulator Schematic
