ADCs with LCD display for battery measurement circuit PIC16F877 protons – in practice Objective: PIC16F877 MCU’s ADC channel on the battery voltage from the okunulup graphic LCD (KS108) screen as a display in the bar.
With this application, read voltages between 0 .. 5V voltage divider circuit for voltages greater than 5V should be added to the circuit. program for the calculation of voltage changes should be made.
PIC16F877 ADC Battery Volt Meter Circuit
Proton ide ADC Example proteus simulation and protons of the project files:
PIC16F877 Battery Volt Meter ADC Proton ide Example
Published: 2010/01/09 Tags: microchip projects, microcontroller projects, pic16f877 projects
PIC16F73 8X8 LED Application Proton ide Example
My first SMD applications; Our circuit consists of eight rows and eight milk. LEDs used 4mm square. If desired number of rows and columns of the circuit can be increased.
