FT245R USB control program and application circuit
| Updated on August 4, 2019
FT245R USB parallel FIFO control IC with USB port, you can control the output, input pins through the program. The author used the program prepared by the manufacturer, by making the application circuit is a simple and direct, there’s little element circuit. FT245R USB control utility has been tested on Windows 7 32 bit, 64 bit
ft245r-usb-fifo-kontrol-program-windows
schematic-ft245r-usb-fifo-kontrol-circuit-windows
In addition, in a file with a different interface for Visual Basic code FT245 is in Oregan and driver files for other examples ftdichip.com/CodeExamples and ftdichip.com/FTDrivers
source: qubbeks.puslapiai.lt/articles.php?article_id=35 all files:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-22725.zip
Publication date: 2014/02/24 Tags:
2 Comments “FT245R USB control program and application circuit
    3x3x3 LED Cube with PIC16F628 microcontroller circuit
    The market plenty of 4 x 4 x 4 led cube was made. I have made 3 x 3 x 3 led cube we also differ. Led cube in each layer is made up of 3 × 3 cut into 3 layers 9 ledden and 27 LEDs.
    Led Cube circuit software and new animations. Each floor minus the ends of the pressure circuit, K1, K2, and K3 connect the writer places. the first layer on a printed circuit board connected to the tip of the pressure circuit, K1, dizileceğinden. Printed circuit board on the 7805 5V regulator IC there if you want to use this version of the circuit with the input voltage must be at least 8v 12 can be used if you have a 5v regulated supply already voltda if there is no need to use 7805. If you are interested in and the Led cube circuits is less with this project will be useful to start your experience.
    FT245R USB-Steuerprogramm und Anwendung Schaltung
    FT245R USB-parallel FIFO-Steuer-IC mit USB-Anschluss, können Sie kontrollieren Sie die Ausgangs -, Eingangs-pins durch das Programm. Der Autor verwendet das Programm, vorbereitet durch den Hersteller, durch die Anwendung Schaltung ist ein einfacher und direkter, es gibt wenig element Schaltung. FT245R USB-Steuerprogramm wurde getestet unter Windows 7 32-bit, 64-bit
