Boreas running Linux directly from the CD, simulation, printed circuit board and diagram drawing, on issues such as the PIC programming software that contains a custom Linux operating system Boreas Linux, Knoppix 3.6 is based. There are in electrical and electronic related software. CD. ‘The Documents folder of some of the documents contained in this software are
Boreas LINUX contains a few of the power electronic software:
Linux Simulation Programs
Gate Tk 1.8.4 / AND, OR gates, flip flops, buttons, LEDs consist of elements such as software testing digital circuits
Ksimus 0.3.6 / Digital (Logic) Simulator: Krelais 0.2 / Electrical intended for the timer and switch circuits consisting of testing a program.
NG SPICE, 0.5 / resistor, inductor, capacitors are, transistors, op-amps and so on. prepared using electronic element circuit test and that the results, a simulation software modules.
Gnucap 12:34 / SPICE engaged in the same process with a different program.
1.3.34 GTK Wave / Electronic wave of audience
A Gwav 20031224
Linux PCB Programs
1.99J PCB / Printed circuit drawing program.
Gerbv 12:16 / printed circuit board used in a program to read the standard Gerber files
Linux Package Programs
GEDA 20040111 / Scheme and the aforementioned PCB drawing program, a package consisting of gwav program.
6:05 Electric / Printed circuit schematics and simulation package program that can be done.
Programs Linux Micro controller (compilers, etc.. Programs)
Gpsim 00:20:14 / PIC wrote a software program that you can test.
Gputils 0.12.4 / a software package designed for PIC microcontrollers. (Assembler language for your own special algorithm
Jalan 0.4.60 / Pic ‘s prepared for and PIC programming is a programming language which greatly simplifies the GNU GPL license.
SDCC 2.4.0
Linux Schematic Programs
XCircuit 03.01.19 / circuit diagram of a successful program to draw added.
Other Linux Electronics Programs
pgcalc 2.2 / calculator with advanced features
Linux Electronics Programs Pack CD Download;
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-69.zip
Publication date: 2008/01/12 Tags: electronics software tools
100 Watt Stereo Amplifier STK4231
STK4231 2x100watt two-channel stereo amp circuit power supply circuits on the same PCB printing do not need to create additional PCBs.
Linux-Elektronik-Programm-Paket
Boreas laufen Linux direkt von der CD, Simulation, Leiterplatte und Diagrammzeichnung, auf Themen wie die PIC-Programmiersoftware, die ein benutzerdefiniertes Linux-Betriebssystem Boreas Linux, Knoppix 3.6 enthält, basiert. Es gibt in elektrischen und elektronischen Software. CD. ‘Die Dokumente Ordner von einigen der Dokumente in dieser Software enthalten sind
Boreas LINUX enthält einige der elektronischen Energieversorgungssoftware:
Linux-Simulationsprogramme
