Display the easiest way to check is to assign a variable for each digit. This embodiment is controlled by display tmp. Which if it is to be shown on the display of the directory in which the number of personnel assigned to the desired number.
For example, tmp [0] = 5 5 is shown on the display by assigning the first. Tmp [7] = 9
9 is shown in the display by assigning end. If you are asked to show anything on the display to the corresponding variable assignment is sufficient to 0xFF.
Nested for loops using the relevent content of the variables is given by changing the marquee air. Tmp contents of the array is scanned at each cycle the display changed.
Display Control Proteus isis circuit drawing;
Hi Tech C Example Display Control code and proteus isis circuit files:
Published: 2011/01/14 Tags: hi tech c examples, microchip projects, microcontroller projects
Display Control Digits to Variable Assignment Hi Tech C Example
