Digital Electronics Circuit Examples
| Updated on September 9, 2024
Of people interested in digital electronics that would work quite integrated door of a document, a lot of examples on how to use the schema’s narrative is based on schemas, so not a problem because the language is english
Basic-DTL-Inverter-digital-electronic
High-Speed-TTL-HTTL
ELE 312 Digital Electronics
DeMassa and Ciccone, Digital Integrated Circuits, John Wiley & Sons.
Taub and Schilling, Digital Integrated Electronics, McGraw-Hill
• Basic Properties of Digital Integrated Circuits
• Diode Digital Circuits
• BJT Digital Circuits
– Ebers & Moll equations
– Transistor modelling
– State of transistor in a circuit
• Resistor-Transistor Logic (RTL)
• Diode-Transistor Logic (DTL)
• Transistor-Transistor Logic (TTL)
• Schottky Transistor – Transistor Logic (STTL)
• Different TTL Gates
• Emitter-Coupled Logic (ECL)
• MOS Digital Circuits
• NMOS Gates
• CMOS Gates
http://eng.harran.edu.tr/~nbesli/SEG/GATE%20Circuit%20samples.pdf
Publication date: 2011/06/02 Tags:
1 Comment “Digital Electronics Circuit Examples
    Nicd Nimh Battery Charging Circuit PIC16F876 Delta-Peak
    Control the battery charging circuit with PIC16F876 150 mA power in 6000 NiCd, NiMH batteries can be recharged circuit 50 to the power of 2 amps. pic output 2 MOSFETs (irf9540, smp60n) used battery fast charging also the voltage of 0.4 volts, which is under the battery for a shock, the recovery system have a circuit partially made ​​easy but quite a detailed work plan there (Delta-Peak, PWM etc.)
