Hi friends,
As our name suggests in this circuit multifunction power supply. However, its share has been to make the circuit of the bay I barely find time. I have my bass with the PCB of the card, but you can see the slight differences based on PCB y. If you change the PCB will be updated again. Boxing suboptimal in nature, 90% have done with the material at hand.
I had my two-piece aluminum wheels and paint color is the end of alum. On the second floor in the front portion could feed only became a little foamy. Chipboard screws was a little over 24 grains but also sturdy enough. Transformer midpoint of the double sekonderl did the drawing. Can withstand 35V dc voltage of the regulator according to the datasheet (LM317 bit more), but a high rate of risk and heat it up when I do not need to go. Transformer output voltage of the capacitor values should be used twice. Insurance is the 3-4A max. enough. 10mA LED current for the LEDs to get the standard cuff. Resistance account each time I do not need to tell you, those who do not may find taking 2 minutes. You can write your questions and problems, without hesitation, take it easy …
Tests for power supply PCB drawings and diagrams:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-22298.zip
Publication date: 2013/11/13 Tags: power electronic projects
Development Boards LPC1114 LPC1343 LPC2103 LPC2148 ARM
ARM Development boards PCB designs very good LPC series ARM, ARM7, cortex-M0 tsarımları, development of reference cards, sets the schema and PCB drawings eagle ARM experiment prepared with the given sample files and source brd sch ARM projects (the Code Base of Flash Magic, ARM, ARM tft oled) ARM code examples.
LPC1114 recommendation planning open source hardware reference design NXP Cortex-M0 based LPC1114
LPC1343 recommendation planning open source hardware reference design for NXP USB-enabled, Cortex-M3 LPC1343
LPC2103 recommendation planning An open source freely reusable hardware reference design NXP ARM7-based LPC2103
LPC2148 recommendation planning An open source, freely reusable reference design for NXP ARM7-based LPC2148
Konstante Spannung, Leistung Netzteil Set für Experimente
Hallo Freunde,
Wie unser name schon sagt in dieser Schaltung Multifunktions-Netzteil. Jedoch seinen Anteil hat, um die Schaltung auf die Bucht, die ich kaum Zeit finde. Ich habe meinen bass mit dem Leiterplatte der Karte, aber Sie können die geringfügigen Unterschiede beruhen auf der platine y. Wenn Sie die Leiterplatte wieder aktualisiert. Boxen suboptimal in der Natur, 90% getan haben, mit dem material in der hand.
