DAC Circuit CS8416 CS4398
| Updated on July 26, 2024
Digital audio applications have not done anything but CS8416 (192 kHz Digital Audio Receiver) and CS4398 (CS4398: 120 dB, 24-Bit, 192 kHz Stereo D / A Converter) integrated carried out with the DAC module circuitry of the person concerned may be useful to PCB drawing is so much quality
What is the DAC?
DAC, DAC or D-to-A (Digital to Analog Converter) that can be translated into our language as digital-to-analog converter is a special identification. Especially since the emergence of the CD, the media having the recorded data due to digital data converted into analog has been used for the purpose. Mounted into the chassis of a CD player, although as will be used as a separate device.
In particular, appears in separate use professional equipment. The purpose of the CD reading mechanisms of mechanical vibrations and other electronic components inside the device during the digital to analog conversion is to minimize interaction. With different technologies, though, CD, SACD, DVD-like digital recording platforms all used to do
DAC Circuit
d-a-c-dac-cs8416-cs4398-d-to-a-digital-to-analog-converter
cs8416-cs4398-dac-schema-dac-circuit
CS8416 CS4398 DAC Module eagle pcb diagram:
Publication date: 2010/07/15 Tags:
1 Comment “DAC Circuit CS8416 CS4398
    For all the television remote control (just off)
    90% of all leisure joke circuit television (including plasma, LCD) is said to work 30 … 50 meters in open space closes the television. Circuit made ​​ATTINY85V-10 micro-controller circuit with two 1.5v AA battery is working with quality alkaline batteries be used in the operating performance of the circuit increases.
