Computer Controlled Robot Project CD Rom Modification
| Updated on August 3, 2019
What is being done from a CD-ROM when the CD ROM is actually a normal show details in the order given to the electronic components as well for the construction of the robot has a lot of useful mechanical parts. The author has set up the printer parts and robot have done a very good system L293 is used for motor control circuits based on PIC16F628 pic prepared for computer control and java java applet source code shared.
robot-hobby-circuits-free-electronic-circuit-robotics-project
Source: habrahabr.ru/blogs/DIY/134178/ alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-18302.zip
Publication date: 2012/01/13 Tags: , ,
1 Comment “Computer Controlled Robot Project CD Rom Modification
    12V AC – 24V DC voltage doubler
    12 Volt AC voltage capacitors and 24V DC voltage doubling can be obtained. This dc voltage current, capacitors and transformers of capacity depends on the strength of the bridge diode. How much is all this constant 24v outlet in if you kullanamass efficiently. When the current is not continuous in snatches spend more time charging the capacitor will collect will increase efficiency.
    Note: This is the effective value of 24v. capacitors max. peak value of about 33v outlet stores and therefore you can read the value. This tolerance may differ in voltage transformer transformer from.
