Guitarists use of the mesh a pedal model Box of Rock circuit gain, tone, volume, boost control’s bs170 MOSFET and passive components based on the noise ratio is very low absolute best performance to get the 9v battery should be fed resistors metal film 1% tolerance should be Box of Rock distortion pedals have all the details of the circuit pCB schematics, layout, bill of materials and so on.
Source: guitarristas.info/foros/clon-box-of-rock-para-avanzados/63444
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-18377.zip
Publication date: 2012/01/15 Tags: audio control circuits
20Led Stereo VU Meter Circuit KA2281
Previously KA2281 20 LED mono VU Meter to the circuit I shared the stereo version also am sharing this circuit 2 ka2281 used pcb printed circuit board dimensions mono version of the same operating voltage 12v dc R – L audio input located on the knob with LED combustion can adjust the level printed circuit sprint layout was prepared by
Distortion Pedal Clone Circuit Box von Rock
Gitarristen verwenden das Netz ein Pedal-Modell Box von Rock-Schaltung Gain, Ton, Lautstärke, Boost-Control-BS170-MOSFET und passive Komponenten basierend auf dem Rauschabstand ist sehr niedrig absolut beste Leistung, um die 9V-Batterie sollte Widerstände Metallfolie 1% Toleranz zugeführt werden Box of Rock-Verzerrungspedale sollten alle Details der Schaltung enthalten, Schaltplan, Layout, Stückliste und so weiter.
