Authors at the bowling alley I have to use a 60-second timer circuit rules should prepare 60sec. ball in the need to throw 🙂 Anyway circuit pic16f876 microcontroller based on the output of the 2N2222 transistors with a strengthened SMD LEDs are driven writer stopwatch circuit oversized display has not used instead SMD LEDs display prepare software mikroC prepared with the C source and hex code are also proteus isis simulation files pcb drawings there is
Circuit power up the “START” button is pressed 15sec countdown begins. stayed 1 .2 seconds, buzzer, raspy singing meanwhile counting buzzer is silent when the time expires buzzer, 1 .2 seconds seconds long term singing and counter back to the beginning in addition reset and re-count-Buttons there …
source: fabrice.sincere.pagesperso-orange.fr/cm_electronique/projet_pic/compteur_petanque_2/compteur_petanque_2.htm alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19937.zip
Publication date: 2012/11/08 Tags: microchip projects, microcontroller projects, pic16f876 projects
Battery Charge Circuit 12V 12AH
Lead Acid 12V 12AH battery charging circuit PIC16F876 microcontroller based on the 16f876 LEDs and battery level show and start, stop doing their work forces in the sight of the voltage, current, adjustable L200 regulator IC is used 12V 12AH battery charging circuit’s source mikropascal codes and Proteus ARES pcb, isis simulation There are files
60 Sekunden Stoppuhr-Schaltung
Autoren auf der Bowlingbahn muss ich eine 60-Sekunden-Timer-Regeln verwenden, sollten 60sec vorbereitet werden. Ball in der Notwendigkeit zu werfen 🙂 Anyway Schaltung pic16f876 Mikrocontroller basierend auf dem Ausgang der 2N2222 Transistoren mit einer verstärkten SMD-LEDs sind angetrieben Schreiber Stoppuhr Schaltung übergroßes Display hat statt SMD-LEDs verwendet Anzeige vorbereiten Software mikroC mit der C-Quelle und Hex-Code vorbereitet sind auch Proteus Isis Simulationsdateien PCB Zeichnungen gibt es
Einschalten der Schaltung Die “START” -Taste wird gedrĂĽckt 15 Sekunden Countdown beginnt. blieb 1, 2 Sekunden, Summer, krächzender Gesang inzwischen zählt Summer ist nach Ablauf der Zeit Summer, 1, 2 Sekunden Sekunden langfristige Gesang und Zähler zurĂĽck an den Anfang zusätzlich zurĂĽcksetzen und neu zählen-Tasten dort
