Bitmap (BMP) Protel PCB converter
| Updated on June 29, 2023
Protel printed circuit converter program that you can use in a drawing program. Language is English, but very easy to use and does not require installation
Bmp image formats PCB in Protel PCB Files Format to turn the program into
BITMAP to PROTEL PCB CONVERTER
This program was designed to allow importing of bitmap images onto a Protel PCB. The ouput of this program is a generic Protel PCB file. Simply open this PCB design in the PCB editor, select and copy this area. Then paste the image onto your circuit board design.
To use this program click on Input Bitmap Choose. Select a BLACK and WHITE image. Although a color image may be chosen the program only looks for BW pixels. You may choose the board layer but with cutting and
pasting it really doesn’t matter. You may also scale the image and perform simple transformations. Finally click on Output PCB choose and select and output filename. The PCB image will then be generated.
This was a quick and easy hack to get an image onto a PCB. It serves my purpose and it may be of some use to you. I release it AS-IS.
This is unsupported freeware copyright ©1998 by Paul D. Fincato. Written in Borland C++ Builder 3.0.
No warranty for fit nor purpose is implied. Use this sofware at your own risk, the author, Paul D. Fincato, assumes no liability for use or misuse.
Protel is a registered trademark of PROTEL INTERNATIONAL PTY LTD and property of it’s registered owner.
(Visit them at www.protel.com)
BORLAND is a registered trademark of INPRISE CORPORATION and property of it’s registered owner.
(Visit them at www.borland.com) Absolutely THE BEST 🙂 C++ development environment!
Paul D. Fincato
[email protected]
Bitmap (BMP) Protel PCB converter download:
Publication date: 2008/01/10 Tags:
2 Comments “Bitmap (BMP) Protel PCB converter
    Op Amp Designer inverting non-inverting calculation
    Particularly with 741 opamp can use a simple calculation program is free sample circuits with electronic information displayed
    Inverting and Noninverting op amp, a good program can do calculations with ease. The program was tested on windows xp professional
    Opamp Desinger program
    In order to make the Operational Amplifier (Windows 3.) program the best that it can be, and to better serve your needs;
    This form is provided for your feedback. If you have any comments or suggestions on the program, please use this to communicate that information.
    Bitmap (BMP) Protel PCB Konverter
    Protel gedrucktes Schaltungskonverterprogramm, das Sie in einem Zeichnungsprogramm verwenden können. Sprache ist Englisch, aber sehr einfach zu bedienen und erfordert keine Installation
    Bmp Bildformate PCB in Protel PCB Dateien Format, um das Programm in
    BITMAP zum PROTEL PCB CONVERTER
    Dieses Programm wurde entwickelt, um den Import von Bitmap-Bildern auf eine Protel-Platine zu ermöglichen. Die Ausgabe dieses Programms ist eine generische Protel PCB-Datei. Einfach dieses PCB-Design im PCB-Editor öffnen, diesen Bereich auswählen und kopieren. Dann füge das Bild auf dein Platinen-Design ein
