Circuit ne555 and 74393 circuits based on single piece is tested with the rgb led Strip Ribbon if you want to use more than the output of the led with the necessary tubing circuit transistors used in 12v 74393 works with the integration of LEDs with 100 k potentiometer connected to 555 speed can be adjusted. The circuit works for sure on the perforated plate printing circuit diagram and list of materials.
RGB Led Strip Effect Circuit test
RGB Led Strip Effect circuit schematic
Publication date: 2012/03/21 Tags: 555 timer circuits, analog circuits projects, led projects
Advanced Development Board for ATmega32
aha before the “AVR Test Kit (professional usb ISP programmer)” shared the most detailed I’ve ever tested, the project experiment kits, a more advanced system, similar to the project development was one of the cards made for ATmega32. I2C, USB, display, led, microphone input, output units, stepper motor driver, etc.. a lot of vehicles on a single card. The card I have a ps format and pcb drawings kicad sizes must be construction drawing of single-sided pcb, but a little easier.
