AV800 Amp Forum application @fatih_celebi24 my brother have been sharing it sharing be noted that the following description has been a long time thanks for sharing it @fatih_celebi24
Hello, I tried to draw a long time ago AV800 Amp just as a hobby I decided to post my circuit made and were tested.
N-Channel 5 A P-channel mosfet 5 mosfet was used to drive a solid 10, It is able to provide a feed.
The solid floor is drawn in a format that can fit A4 power power supply 100V capacitor 10000mf stop. Supply Voltage +\- max. 90V kind. recommended +\- 60V AC. ideal +\- 75vdc like you can use.
note careful notice of the project av800 power amplifier Operating voltage is too high, the capacitor connections + – reverse polarity if you connect to the circuit line may be large explosions before running the insured electricity at high voltage,protective eye glasses
AV800 amp pcb circuit files:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-25445.zip
Publication date: 2016/04/22 Tags: audio amplifier circuits, transistor amplifier
Spectrum Analyzer Circuit Arduino RGB Led Strip
the spectrum analyzer circuit a project of Arduino Duemilanove Module 7-band graphic equalizer on board sound on the ground floor MSGEQ7 used to integrate MSGEQ7 is a very talented 8-pin ICS in the frequency bands of the 63-Hz and 160-Hz, 400-Hz, 1-kHz, 2.5-kHz, A 6.25 kHz and 16kHz RGB PCB for Arduino MSGEQ7 spectrum analyzer circuit and the source code for the project has been given a drawing…
Arduino Led Spectrum Analyzer
Verstärker-Projekt 500W 1000W
N-Kanal 5, Einen P-Kanal-mosfet mosfet 5 wurde verwendet, um Laufwerk ein solid-10 in der Lage ist, einen Netzteil.
Den festen Boden gezogen wird, in einem format, die passen A4-power-Netzteil 100V-Kondensator 10000mf stoppen. Versorgungsspannung +\- max. 90V Art. empfohlen +\- 60V AC. ideal +\- 75vdc wie Sie verwenden können. Verstärker av-800
