USB Business Card with attiny85
| Updated on August 3, 2019
Attiny85 Atmel microcontroller with USB Business Card project established quite interesting circuit with very few elements attiny85 16.5 MHz internal RC oscillator frequency used. USB connector on the USB socket on the PCB designed to stop loose plaque thickness of 1.6 mm on the pcb printed circuit previously shared attiny85 USB Password Generator usb interface as software applications, as in made ​​with V-USB driver. USB Business Card is connected properly to the computer from the keyboard opens up notepad program “Caps” key 2 times the pressure information contained within the microcontroller automatically written to the notepad window ..
writing source code is also available for the project in the C source line 452, hex codes and other sources, there are eagle files ..
// PLACE TEXT HERE
//puts_P(PSTR(" ")); // test size
puts_P(PSTR("Frank Zhao\n\nEmail: [email protected]\nWebsite: http://www.frank-zhao.com/\nPlease contact me for a resume\n\nExperienced in:\n* electronics design\n* multiple programming languages\n* web design and development"));
blink_count = 0; // reset
attiny85-ile-usb-pcb-business-card-vusb
Source: frank-zhao.com/cache/usbbusinesscard.php alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19895.zip
Publication date: 2012/10/08 Tags: ,
2 Comments “USB Business Card with attiny85
    3 Axis CNC Machine drills
    CNC Machines classical LPT port controlled if all of the details, adjustments, granting and regularly have a project with was interested I will not lie to make one wanted 🙂 author CNC machine with the printed circuit scraping, printed circuit board drilling, the wood on the scraping and so on. DREMEL 300 for use in works such as drills used .. In addition, scraping scatter of the burr for drilling a broom made ​​simple fan mounted on the drill bit to have my hosting company ..
    CNC machine frame and other parts of chipboard and sheet metal parts made ​​of all dimensions provided for controlling CNC KCAE 4 used port settings are also on the CNC PCB to scrape sprint layout low battery G-code to output picture has been described in
    USB Visitenkart
    Attiny85 Atmel Mikrocontroller mit USB Business Card-Projekt etabliert ziemlich interessante Schaltung mit sehr wenigen Elementen attiny85 16,5 MHz internen RC-Oszillator-Frequenz verwendet. USB-Anschluss an der USB-Buchse auf der Platine, um lose Plakette Dicke von 1,6 mm auf der Platine gedruckten Schaltung zuvor geteilt attiny85 USB Password Generator USB-Schnittstelle als Software-Anwendungen, wie in V-USB-Treiber gemacht. USB-Visitenkarte ist richtig mit dem Computer von der Tastatur verbunden öffnet Notizblock-Programm “Caps” -Taste 2-mal die Druckinformationen im Mikrocontroller automatisch in das Notizblockfenster geschrieben ..
    Quellcode schreiben ist auch verfügbar für das Projekt in der C-Source-Zeile 452, Hex-Codes und andere Quellen, gibt es Eagle-Dateien ..
