USB UART Converter PIC16F88 Circuit Attiny2313
| Updated on August 24, 2023
Recently circuit on the web I’ve seen perform this southern been applying If we are talking application atmel’s famous ATtiny2313 achieves with USB UART converter further circuit 8bit I / O 128-byte EEPROM 32-byte FIFO buffer a lot as have the ability to detailed information AVR309 application note exists in the circuit did and it works just fine.
Attiny-2313-usb-uart-
ost important of all circuit pc FT232 chip as USB UART converter not see this as the circuit is open source is the device name of the asm code of the change that you want can name the same way PCs at the avr309.inf and avr309.rc driver files where necessary by editing the companies you want information you can enter.
Circuit example for delphi code also available from me this code exploiting a test circuit made ​​circuit PIC16F88” s 0 channels received from the 8-bit analog information to the PC is sending from the PC first byte sent 16f88 the PWM module with 0-5 volts earns.
Works with 3.3-volt circuit, but the USART module with 16f88 communication problems arise because I fed 5 volts desktop PCs do not know what the problem might be problems with the notebook out.
usb-uart-yeni-donanim-bulundu
rs232-ayar
usb-uart-ozellikler
USB to UART converter project’s source files:
Publication date: 2009/10/24 Tags: , , ,
1 Comment “USB UART Converter PIC16F88 Circuit Attiny2313
    Digital Audio Control Circuit Nokia 3310 LCD Atmel ATmega8 TDA7439
    My old chassis while stirring an old stereo on the chassis tda7439 found it and integrate these with making an application decided and ultimately such a nice application appeared application If we are talking circuit tda7439 digital volume control operate in a supervisory ATMega8 LCD as in my hand 3310 lcd because 3310 LCDs to I used to tda7439 integrated audio from -47-0 0-30 dB and -14 dB gain – from +14 dB bass mid treble control is also balancing control. application also has 4 stereo inputs as a single entry blank for the others I’ve tested works very well integrated with the LM3886 and the setting is doing.
    TDA7439 Digital Audio Control Project
