ATtiny2313 microcontroller circuit with MAX232 PC connection can be established based on the pc program with wav file loading the output of the power amplifier TDA2003 integrated amp
Atmel Wav Player Circuit Test
The electronic circuit it ATtiny2313-mas* mikrovezérlo that of a circle is being built. AVR-hez* the memory IC (AT45DB4161) a voltage divider is attached with resistances since the memory is a maximum 3.6V-ot* is able to tolerate it. According to this Z-diódás with a stabilizer 3.3V-ra* the supply voltage is portrayed for IC. From IC it adatvzeték* the AVR re is attached directly since he is AVR the 3.3V-ot* H can perceive it as a level yet.
The digital code being equal to the sound AVR single R-2R turns it into an analogous sign with a network, mainly the cost effectiveness and I decided it because of the simplicity at this solution. The strengthening grade follows this. For strengthening IC TDA2003-mat* I singled it out mainly his plain connection, his price, and the equivalent, cca. 10W-os* because of his leave performance.
To put on a sound for the apparatus, to delete we are top notch with the help of a computer. The electronic circuit sorosporttal* is attached to the computer, this an MAX232 type next fitting accomplishes it through IC
Source: hobbielektronika.hu/ Wav Player Circuit pcb aschematic source code Alternative link:
Publication date: 2008/04/08 Tags: avr project, microcontroller projects
150W Mosfet Amplifier Circuit
value can be between 40-50 mA bias current. potentiometer circuit upfront with it, but I did my ear again setting potentiometer at the point I left the clean sound. though it has the same tone knob at every point, but I left it in the middle value of b. have detailed information here. TR6 and TR7 2SJ162 2SK1058 circuit used IRFP240 IRFP9240 was used instead of
