ATMEL AT89 series on various projects for the development of programming you can do trial and a circuit
Development board for AT89SXXXX This is a development board for ATMEL AT89 series or ATMEL ISP.It uses In-System Programming .Easy to use for developing your ATMEL MCS-51 base projects Support ATMEL AT89S series such as AT89S51, AT89S52, AT89S53, AT89S8252.(DIP 40 pin devices) Use In-System Programming(ISP).Low voltage programming RS232 X 1
This is a development board for ATMEL AT89 series or ATMEL ISP.It uses In-System Programming .Easy to use for developing your ATMEL MCS-51 base projects.
Features
RS232 X 1 .
5 V regulate on-board.
No need any tools or programmer devices .
connector for all I/O.
Requite one PC parallel port for ISP.
Software supports for All Windows.
easy to build your own single side PCB.
Require power supply from DC adpaptor 9-12VDC or AC
How to use ATMEL ISP.
To use this ATMEL ISP board you need to download software ISP-3v0 developed by Muhammad Asim Khan and distributed by Prof. Wichit ‘s website or download at the buttom on this page.
After download software.
1. Connect ATMEL ISP cable to PC parallel port and power supply. (see Fig.5)
2. Run software ISP3.0 for Windows95/98/ME use ISP-3v0.exe and WindowsXP/2000/NT use ISP-XP.bat .
3. Select your devices from drop down list menu.
4. Click “Open file” to open hex file.
5. Click “Write” to program device.
How to use RS232 port.
To use RS232 port ,first build a simple RS232 cable.
Atmel AT89 Series Experiment Development Board pcb schematic
Publication date: 2008/01/11 Tags: development board projects
AT90S1200 D.D.S. Function Generator
The presented project is a function generator for sinusoidal and square signals production. The output frequency covers the range from 10 Hz to 100 KHz with a step of 2 Hz.
The waveform synthesis is based on the D.D.S. technique (Direct Digital Synthesis) and the output frequency is selected through a microcomputer with an embedded thumb wheel keyboard.
Function Generator Technical specifications
Output Frequency: 10 Hz – 100 KHz (step 2 Hz)
Output Voltage:
Sinus: 0 – 20 Vp-p
Square: 0 – 20 Vp-p
TTL: 5 V
Output Resistance: 1 KOhms
ATMEL AT89 Serie auf verschiedenen Projekten für die Entwicklung der Programmierung können Sie versuchen und eine Schaltung
Entwicklungsplatine für AT89SXXXX Dies ist ein Entwicklungsboard für ATMEL AT89 Serie oder ATMEL ISP.Es verwendet In-System Programmierung. Einfach zu bedienen für die Entwicklung Ihrer ATMEL MCS-51 Basis Projekte Unterstützung ATMEL AT89S Serie wie AT89S51, AT89S52, AT89S53, AT89S8252. (DIP 40-polige Geräte) In-System Programmierung (ISP) verwenden. Netzspannungsprogrammierung RS232 X 1
