Portable RF Jammer Circuit ATmega48
| Updated on August 3, 2019
So far I have ever seen , tidy and with all the resources shared jammer circuit project design, it’s very smart Sizes also pretty small pocket on the internet a lot jammer circuit , however, this circuit more like simple but integrates most of us in our market does … Circuit of the printed circuit board 3 floor consists of output power in the 1watt high band , low band 3watt
Jammer circuit mobile phone battery with 3.7v supply provided with integrated voltage converter dcdc used in raising the necessary parts . Jammer on the ATMEGA48 microcontroller , ROS2500 , ROS1200 , SXE- 389, LM358 , etc. ad8402 . abundance outside the integrated voltage regulator and converter used dcdc
CAUTION Jammer frequency to a frequency of the same value , is a device to signal that suppresses the original signal . jammer is forbidden to use this project to share the purpose of source code and PCB drawings is that the different projects, the PLLs , high frequency for operations such as C code may work influenced, may also RF PCBs in designing resource eagle pcb design would be helpful
self-tuning-portable-rf-jammer-dual-pll-therefore
jammer-circuit-pll-rf-jammer
Source: ladyada.net/make/wavebubble/index.html alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19069.zip
Publication date: 2012/06/12 Tags: ,
1 Comment “Portable RF Jammer Circuit ATmega48
    DTMF Receiver Sample Test Circuit KT3170 MT8870
    Many phones use a DTMF receiver is integrated . The majority of them are manufactured by companies that Motorola MT8870 is integrated . There are 18 pieces on this integrated pin . However, this is not integrated within the phones alone , can also be used in various applications . However, how to integrate the various projects that are used and it is not necessary to yield engineers and technicians felt the need to integrate these are tested separately .
