Digital radio circuit TEA5767 AT89S8253
| Updated on August 3, 2019
TEA5767 is a digital radio, especially mp3 and fm radio module @ETE before “TEA5767 Pic16f628 Digital PLL-controlled FM radio receiver system” article is controlled with the Pic16f628 microcontroller used in this project, the radio project shared AT89S8253 audio output amplifier IC with raised TBA820. There are additional features not included in the standard controls on the circuit, but boxing is very chic
tea5767-radio-atmel-89s8253-microcontroller
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19492.zip
Publication date: 2012/08/17 Tags: ,
1 Comment “Digital radio circuit TEA5767 AT89S8253
    Switch Mode Power Supply Circuit SG3525 IR2110 900W SMPS
    SMPS circuit have 3 version of the 700w (+-50v 50khz), 800w (+-42v 60khz) and 900w (+-70v 50khz) circuit diagrams for the same smps pwm control output is used to drive the integrated MOSFET sg3525 ir2110, but according to some of the values are different, the forces of the output of the SMPS circuit voltajlarına has been prepared with proteus aras 800w pcb çizimide. High power smps circuits that can be used to run symmetric lecture.
