PIC16F877 Car Wiper Control Circuit
| July 25, 2024 Updated
In this article, a system used in cars which will give information on the wiper control. I made the second one PWM circuit simulation engine will run the servo motor and water spray relay is located. Circuit PIC16F877 microcontroller based on the engine version was used in the IRL530N MOSFETs.
oto-silecek-kontrol-isis-devre-motor
Buttons with the procedure I’ve created three different studies. F1 button is pressed only once to move the wipers are waiting. F2 button is pressed whether the wipers are waiting for this process 3 times. F3 button is pressed, the wipers make this process four times the water sprays at the same time. Simulation of the water jet engine instead I used the relay with his driver. Working PWM PWM signal to the servo movement produced is achieved.
Car Wiper Control Proteus isis simulation
pwm-logic1-logic0-1000us-2000us-20ms
author: Ediz AĞARER – Car Wiper Control Circuit proteus isis circuit and code files:
Published: 2010/06/04 Tags: , ,
1 Comment “PIC16F877 Car Wiper Control Circuit
    Q-matic Circuit Application of PIC16F877 Microcontroller
    In this article I used in banks and hospitals will give information about the Q-matic s. I’ve done a routing circuit board (main board) and consists of three separate teller. Routing PIC16F877 on board, if the teller did not use pic16f876 in each. Teller as the officer may increase, decrease or can be reset. Every teller has been working with the same logic.
