an Advanced Resistor Calculator program on the market that I share in special value resistors in the calculation that are not available to prepare a program that makes…
Resistor calculation program, after opening the “required” section, you write the value of the resistance K (clay-Ohm) M (mega-ohms), etc. you can use abbreviations, or you can write directly on the figure as, for example, 1K 1000
The measured values are patched to the desired value directly in OHMS
Then right-select the shape and resistance of the connection in the menu “Calculate” button click OK a warning window will appear indicating the duration of said calculation the Calculated values, which gives more than one result that will appear after the program, if appropriate, the resistors are located you can use it if
In the right menu of resistor 2 serial ports, 2 parallel connection resistor, parallel connection of resistor 3 and resistor 2 Parallel + 1 Serial resistor calculation can be performed selecting the connection method, whether batch, select them all and select the individual you want to view all connection types according to the results the list a lot longer otherwise my suggestion would be the only choice in the menu crashes when you click on the button in light resistor
Program files:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-25450.zip
Publication date: 2016/04/22 Tags: electronics software tools
0-24V 0-3A Switch mode Power Supply project STM32F
the STM32F40X in the project based on switched power switch mode works as size too small voltage 0-24 and 0-3a can be made between the current setting information is displayed on LCD screen voltage and current of the RGB LED.
STM32F40X other things that are used outside integrated circuits, transistors, etc. I don’t think it would be found on the market the new generation, but in power electronics for the arm library code all the source code and given a good example.
STM32F Power Supply
Advanced Widerstand Taschenrechner-Programm
eine Erweiterte Widerstand Taschenrechner-Programm auf dem Markt, die ich gemeinsam spezielle widerstände in die Berechnung nicht zur Verfügung stehen, bereiten Sie ein Programm, das…
