SMD 8 Pin SOIC Adapter (DIP Socket)
| Updated on May 1, 2016
I used the SMD integrated circuit designs and making the repair work doesn’t trouble many rarely PCB design to find the ingredients according to the sketch, but it’s unlikely to repair or trials if the normal DIP wire soldered onto SMD 8 pin integrated legs sheath cable is thrown or the thing that you are prepared for the PCB…
soic-adaptor-soic-adapter-smd-adaptor-smd-adapter-8-pin-adapter
but me and a lot of people that uses DIP socket soldering much more affordable .. simple, but useful clue as I said, very rarely used, so to share never crossed my mind, but you see above photos by chance, the net when I saw I wanted to share that need attention socket Precision is actually a bit more agonizing type 16 pin DIP socket to be used in an integrated but it would be cool ..
Publication date: 2013/11/21 Tags:
2 Comments “SMD 8 Pin SOIC Adapter (DIP Socket)
    National Instruments Serial Quick Reference Guide
    National instruments good old hey “LM” series we know if I remember correctly, the integrated circuit 1.2 years ago I bought the firm Texas Instruments TI “” products are produced for a long time, probably still piysada well detailed documentation National Instruments products made in a document prepared by serial connection protocols, 60 KB in a single PDF file has a lot of information.
    SMD SOIC-Adapter DIP Sockel
    Ich verwendet die SMD integrierte Schaltung Entwürfe und die Reparatur nicht in Bedrängnis viele selten Leiterplatte-design zu finden, die Zutaten entsprechend der Skizze, aber es ist unwahrscheinlich, dass eine Reparatur oder versuche, wenn die normale DIP-Draht gelötet auf SMD 8 pin-integrierte Beine Mantel-Kabel ist oder geworfen die Sache, dass Sie bereit sind, für die platine…
