760w amp circuit is quite robust to noise ratio and low power depending on the quality pcb printed circuit drawing of circuit elements to be making more but makes it easier.
Anfi circuit NE5532, LM393, LM393 op-amp fan and temperature controls have on the circuit board pcb layout pcb drawing program with Sprint Prepared for Imaging and Print output can use the free Sprint Layout Viewer Program
Anfi + -41 volt circuit supply voltage of 82 volts dc high voltage is dangerous to be careful. Half of the transistor T10 and P4 potentiometer should be set between 2.1 volts to be given the current value of the key points on the diagram.
In addition to fan cooler that will be connected to the 12-volt LM741 and LM393 `s temperature control node, made with NE5532 opamp’s tone control circuit
760w amplifier circuit pcb schematic Alternative link:
Publication date: 2008/01/13 Tags: audio amplifier circuits, transistor amplifier
AVR Temperature Measurement System
Atmel AVR, Atmel microcontroller series with a super “Temperature Control Measurement System” 16 sensor inputs 4 alarm inputs and the computer’s connection. Temperature measurement, alarm, an exemplary application in the PC communication
This measuring system is used to record the data of up to 24 temperature sensors in the range of -55 ° C to +125 ° C, 3 humidity sensors and an air pressure sensor. Addition, there are still 4 alarm inputs are available, where switching contacts can be connected. The project consists of several components: the sensor module 2, the sensor module 3 with additional air pressure sensor, the small display module 1, the large display module 2a, the LED display module 3 and the PC program “AnzKom” and a web module. The sensor modules record the temperatures and humidities over 1-Wire sensors and monitor the alarm inputs.
760w Ampere-Schaltung ist recht robust gegenüber Rauschabstand und geringer Leistung, abhängig von der Qualität der Leiterplatten-Leiterplattenzeichnung der zu machenden Schaltungselemente, macht es aber einfacher.
Anfi Schaltung NE5532, LM393, LM393 Operationsverstärker Lüfter und Temperaturregler haben auf der Leiterplatte PCB-Layout PCB-Zeichenprogramm mit Sprint Prepared for Imaging und Print-Ausgabe kann das kostenlose Sprint Layout Viewer-Programm verwenden
Anfi + -41 Volt Versorgungsspannung von 82 Volt Gleichspannung ist gefährlich, vorsichtig zu sein. Die Hälfte des Potentiometers der Transistoren T10 und P4 sollte auf 2,1 Volt eingestellt werden, um den aktuellen Wert der Schlüsselpunkte im Diagramm zu erhalten.
Neben dem Lüfterkühler, der an den 12-Volt-Temperaturregelknoten des LM741 und LM393 angeschlossen wird und mit dem Tonregelkreis des NE5532-Opamps hergestellt wird
