74LS160 integrated circuit prensbini a beautiful work to understand the circuit. the chip integrates a signal is applied to the rising edge of the clock input, four output of 0-9 count. every rising edge when a growing, including MultiScan output output by taking the exit number 15, leg nine more 74ls160 can be connected in series to each other.
BCD Decade Counter 74LS160 Example Circuit
SW1-SW4 switch in the circuit are used to control the output. With this switch
After you apply integrated inputs 1 or 0 to the SW6 switch chassis by pulling out the status of the input is transferred to the Anatara. SW6 pulling back plus counting continues from where it left off.
Is carried out with the switch SW5 blackout, all LEDs off. And counting process can be stopped and started to sw7v SW8.
Proteus Simulation files:
Publication date: 2010/11/20 Tags: analog circuits projects
PIC16F877 16X16 LED Matrix 74HC595 Graphic Display Project
Hello Electronics lovers. After a long hiatus, I wanted to write something again. In this article, software-serial basis (soft SPI) and still other applications I wrote using the name for a project I would like to help. 16 × 16 matrix graphic display I share with you my work on the foundations of
I compiled using pic16F877 74HC595 recorder at a speed of 20Mhz with these applications through screening method to create visual graphics display basic circuit diagram of the ISIS software mikroC C and Hex code attached file is available.
We also aim to have you with visual examples to work in 24 × 24 graphic display
Proteus isis circuit 16X16 LED Matrix schematic
