BD911 BD912 Transistor 70W Amplifier Circuit
| Updated on September 7, 2024
Amplifier circuit pcb printed circuit quite stylish become a regular settlement there the supply voltage at high + – 33 volts symmetrical 4-ohm speakers with a 70w power can give 70w power with a 1kHz signal THD rate of 0.057% (THD Total harmonic distortion-Total harmonic distortion) only on departure coil located 1mm wire 13 to be wound spr … 50mA quiescent current adjustable from 40 to 2.5k potentiometer
uni50-amfi-70-watt-amplifier-circuit-transistor-amp
Technical parameters amplifier:
Supply voltage: max. +/- 33V
Output power: max. 70W/4R
Frequency characteristic: 10 – 98,000Hz/-3dB
Harmonic distortion: 0.066% at 70W/1kHz; 0.057% at 70W/10kHz
Intermodule distortion: 0.24% at 65W/ 80+7kHz
Input sensitivity: approx. 0.45V
Current protection: 2×3.15A fast fuses
SR current rate: 12V/us
min. load impedance: 4R
PCB dimensions: 72×56mm
Publication date: 2011/05/11 Tags: ,
1 Comment “BD911 BD912 Transistor 70W Amplifier Circuit
