Hello friends for a long time I worked on the amp my bitirdim.yaklaşık 1-2 years, tube amps and research and my work had, especially in Turkey, says the industry tube amps much about missing that we ( I think this lack , and only the lack of research and Uras caused by lack of will ) I thought this alandada a amp to do , at least it was planning to konudada information .
I have labored so long and at the end of my Uras results I have achieved some positive results . I’m sure many of our friends who want to work on this issue , there are those who even was even , that it sebeptendir now I share it with you here on my work .
Amplifier is a very simple application , only 2 lamp input and output stages are used , stereo birdevr 3 one lamp be done with this simplicity downloaded sound very nice there , especially the upper and middle frequencies a great, I own my work input lamp as the ECC83 output lamp I used the EL84 and 6p43p , future 6p14 , 6p1p experimented with lamps as I plan to put the last point .
Open, as shown in the diagram amp and a few resistors and capacitors present a simple but high quality circuit in a shake for a long time I have done a amfilerd class career as I understand, the best amp is the simplest one.
In the diagram, the cathode bias resistors values did not give the required anode current measuring resistor values need to determine, because of the same brand same model light of the lamps even bias notices, were left stranded on the EL84 instead 6bq5, 6p34p, 6p1p, 6p14 as equivalent wear what happens if you would think about it,
Publication date: 2011/05/20 Tags: audio amplifier circuits, transistor amplifier
Current Limiting Circuit 1W 350ma Power LED
1w power led for rides so easy a handy circuit a few resistors and two transistors is done with MOSFET with 350mA current limit because 1w LEDs used in the circuit used IRFU9024 P channel mosfet instead of similar interventions in any P channel MOSFET can be used.
