PT Series integrated with the first sound system repair in’ve met 2.1, 4.1, 5.1 sound system for a very ICs’s so much quality not considered firms only audio applications are not many areas active in carrying out production, particularly in the market that a lot of control in the pt series integrated there
433 MHz RF transceiver module in this circuit have been checked on the 12 volt relay 4 x 4 button control the receiver circuit PT2272, PT2262 transmitter’s circuit is
Prepared by: @Erdem EFE
PT2262 circuit
remote control encoder paired with PT2272 utilizing CMOS Technology. It
encodes data and address pins into a serial coded waveform suitable for RF or IR
modulation. maximum of 12 bits of tri-state address pins providing up to
531,441 (or 312) address codes; thereby, drastically reducing any code collision and
unauthorized code scanning possibilities.
PT2272 circuit
remote control decoder paired with PT 2262 utilizing CMOS Technology. It has 12 bits of tri-state address pins providing a maximum of 531,441 (or 312) address codes; thereby, drastically reducing any code collision and unauthorized code scanning possibilities. PT 2272 is available in several options to suit every application need : variable number of data output pins, latch or momentary output type.
PT2272 PT2262 Proteus ARES PCB files:
Publication date: 2011/06/02 Tags: analog circuits projects
Digital Electronics Circuit Examples
Of people interested in digital electronics that would work quite integrated door of a document, a lot of examples on how to use the schema’s narrative is based on schemas, so not a problem because the language is english
