I think it’s one of the cleanest I’ve ever shared 400w amplifier circuits. potentiometers for setting the current calm, etc., with no need to make critical areas should be on the same printed circuit board feeding times specified values in voltj power transistors, except with less material. Amplifier output power transistors used 8 2SC5200 working voltage 2x75v dc circuit, placement, assembly drawings and Bill of materials.
power supply for diode bridge 35 amps metal straightening in the sight of the used filter capacitors is 2 pieces 2 pieces instead of 10,000 6800uf uf is better to use the
Note that the 400 watt amplifier circuit, be careful when working with high voltage capacitor connections if you connect the high voltage polarity + – large explosions could be Insured before you run the circuit power line, use protective eyewear
Source: http://construyasuvideorockola.com/proyect_amp_mono_400w_1.php alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19002.zip
Publication date: 2012/05/26 Tags: audio amplifier circuits, transistor amplifier
8 Channel 24 Amp Triac Animation Circuit PIC16F628
Hello Friends
For a long time I did not do my share. I looked at my little library amusement park six months ago I prepared for bi TRIAC 8 Channel 24 saw the animated card. Obviously things I’d forgotten due. After getting a bit of project files I thought I’d share with you.
Card design for amusement parks like I did. More than ever animated card did not come no one complained. Is working without a problem.
In general, if you need to talk a little circuit on the circuit triac BTA24 600BW as I used. According to the triac 25 A current catalog information and can withstand up to 600V for example. Triac MOC3020 to drive the triac driver I used in the optical isolator. Processors have the PIC16F628.
