Class D amp circuits usually bass, a subwoofer is used in practice despite being small in size can offer very high power. There are 3 pieces of 300-watt Class D amplifier circuit ir2104 ir2110 drive MOSFETs irfb23n15d 900 watt 1200 watt amplifier tlp621 driver MOSFETs irfp3415 the ir2110s irfb52n15c 300W Class D amp Circuit, 900W Class D amp Circuit, 1200W Class D amp Circuit
Note: Class D amplifiers have only the one in the original schemes are, inter alia, the pcb drawings 300w. PCB Artwork crafted with sprint layout file in the viewlayout50 program, you can open the file with the output from the printer, 300 lay.
Class D amplifiers circuit files:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-16065.zip
Publication date: 2011/08/27 Tags: audio amplifier circuits, class d amplifier circuit, ir2110 circuit, transistor amplifier
Smart Home Automatic Lamp Circuit Sharp is471f Detector
In the house of the lamp closer or move automatically according to the combustion designed for precision stable working detector circuit … Author automatically house lights approaching, the motion according to the blink used to have enabled sensors used Sharp is471f (Breakbea’m Sensor Sharp-IS471F) sensor control and other processes used to of the project microcontroller pic12f675 pCB, the source schema asm, hex’s all files. The detector circuit, home automation, smart home and can be useful for your projects.
