Speaker Protection Circuit
| Updated on June 21, 2014
High-quality low-frequency chain is relatively very expensive and thus no wonder that they are trying to protect its individual components in every possible way against damage or even destruction of improper manipulation or random problems. One of the possible failures are punctures one of the terminal transistors power amplifiers or any other cause, leading to nesymetrii output.
200w_koruma_devresi
Speaker Protection Circuit PCB
ochranarep_dps-120x120 ochranarep_osaz-120x120
As regards the power amplifier is symmetrical, which normally has a capacity of separate speakers, the speaker or speakers safely leave their existence, as a result of a DC congestion. In these cases it is intended, this structure, which responds to the presence of the DC voltage output that disconnects speakers As a practical application requires intervention in amplifiers, not circuit, despite its simplicity and primitivism, designed for complete beginners.
List of components:
R1, 2 1M2
R3 1k
R4, 5 82k
C1 – C4 10uF / 25V
C5 47uF / 16V
D1 – D6 1N4148
D7 3V6 / 0.5W
T1, 3, 4 BC337 NPN or other
T2 BC327 PNP or other
K1 RELEH820F24C
Source: pandatron.cz
Publication date: 2008/06/14 Tags:
1 Comment “Speaker Protection Circuit
    AT89C51 Square Wave Signal Generator
    Signal generator test is often the recipients of the amplifiers used in the test and repair of this equipment. Used as the signal source. Wave detector, radio frequency used in places such as bridges. Integrated signal generator, the steady operation, because of the cost is low and it is preferable to be mixed. Attractions signal generator used in the experiments 1Hz – 10Hz and 100Hz frequency will produce. When prompted, the program used can be obtained by varying the maximum 500MHz square wave signal.
