Complete Amplifier Project
| Updated on July 28, 2024
In an article I shared an old amp circuit (Mosfet Amplifier 150W) project, more advanced, I applied again with additional circuitry Circuit 4Ω 8Ω speaker with a 100w power 150w with hoprarl able sooner.
Amplifier circuit diagram and PCBs;
150w-amfi-devre-semasi-amplifier-circuit-120x120 150w-amfi-pcb-amplifier-circuit-120x120
Preamplifier circuit
Pre amplifier circuit works fine, I’ve enjoyed it. In addition to the magnetic microphone input with each instrument (guitar, electro-binding, etc.) by connecting guitars, etc. You can use the amp is not very efficient, but can not get the guitar amp for the new starting time will take
preamfi-devresi-preamplifier-circuit-120x120 preamfi-baski-devresi-pcb-preamplifier-circuit-120x120
Power supply circuit
Amplifier power supply circuit I used as a standard symmetric. Preamplifier supply circuit for use again at a standard symmetric but to obtain a more stable DC voltage of the voltage regulating integrated I used. Standard supply circuit diagram that I did not need to draw direct printed circuit board supply circuit diagram so I do not have just printed circuit board. I use the amp with separate power transformers Preamf. Preamf the supply transformer is small print you will see in the pictures I put on the card.
150w-stereo-amfi-projesi-mikrofon-ekolayzir-120x120 amfi-kasa-tam-2-120x120 mikrofon-ekolayziramfi-kasa-tam-120x120 mikrofon-ekolayziramfi-kasa-ust-tam-120x120
amfi-pcb-baski-devre-120x120 amfi-proje-besleme-devresi-120x120 amfi-proje-besleme-devresi-pcb-2-120x120 amfi-proje-besleme-devresi-pcb-120x120 preamfi-proje-besleme-devresi-120x120 amfi-proje-besleme-devresi-power-supply-120x120
Proteus ares pcb files belonging to a amplifier project:
Publication date: 2010/08/18 Tags:
1 Comment “Complete Amplifier Project
    LEDs show Circuit PWM PIC16F628 MPLAB
    LEDs show the pic 16F628 microcontroller on the circuit board assembly prepared with 8 leds pcb design software source quite stylish. Asm,. Hex, PCB’s files also detailed information about the software included in the flow diagrams.
    PWM LEDs
