Now I will say that what is going on E1. apartment blocks of text and drawing attention to the need to be more specific and asked me something like that. He is probably sitting in E1 block
CAUTION Be careful is working with high voltage capacitor circuit connections Beware + – If you connect the high voltage polarity may be large explosions before running the insured Power Line circuit, protective goggles
LED Sign Circuit Simple Schematics
Published: 2009/04/04 Tags: analog circuits projects, led projects
Transformerless LED Light 20LEDs
20 white LEDs connected in series circuit is formed. 220V. Pointing 310V AC current. DC (1.41X220), we obtain and the “220-volt Led Operation” in article 310-volt outlet using the account to be used’re placing stones resistance.
My hands, I had a great saving bulb container I use it to mount and bore a sticker I cut according to his section.
CAUTION Be careful is working with high voltage capacitor circuit connections + Please note – If you connect the high voltage polarity may be large explosions before running the insured Power Line circuit, wear protective goggles
Transformerless LED Light Schematics
