20AMPS 200AMPS Battery Charger Circuit
| Updated on July 7, 2023
Circuit bit confused 🙂 but very powerful and has nice features automatic protection circuit PWM current control is doing the reverse link and a quick charge system has a heat protection
200ah_aku_sarj
The type of a battery: Acid lead battery Nominal filling tenseness: 12V Capacity which can be spent: 20..200Ah Charging current: 0..20A [C/10=@100percnt] Filling tenseness: Acid temperature compensation (optionally automatic) -30mV/°C @14,2V
Capacity 0..200Ah Battery age 0..6v (optional) Stop, filling stopping Riding slowly, filling mode of operation setting Filling modes of operation [Led] Terminal voltage [V] Charging current [A]
Function: automatic Function cycle: 3 (framing, filling, end filling) Launch tenseness: Ub>9V Framing: 9..12,5V-ig* @20percnt [Form] Filling: 12,5…14,2V-ig* @100percnt [Rapid] End filling: …15V @20percnt [drop]
Reverse polarity protection At least tenseness protection (9V) Tirisztor heat runaway protection Network leave protection (program protection) Touch protection: IP20 with defender earthing
Source: hobbielektronika.hu/ 20AMPS 200AMPS Battery Charger Circuit alternative link:
Åžifre-Pass: 320volt.com
Publication date: 2008/04/08 Tags: ,
1 Comment “20AMPS 200AMPS Battery Charger Circuit
