PIC18F452 Graphic LCD Menu CCS C stopwatch Project
| Updated on August 22, 2023
GLCD graphic LCD using PIC18F452 microcontroller on the picture menu, primarily to prepare the necessary photos we draw on our computer. I’ve used MS Paint for this process is already very professional does not need a drawing program will ultimately create a black-and-white photos. No writing required on BITMAP2LCD – Basic Edition software to add and we’ll turn the hex code official. Below you can see bitmaps 128X64 prepared using MS Paint.
Figure-1 Stopwatch screen Figure-2 Stopwatch Registration Screen Figure-3 About Screen
kronometre-ekrani kronometre-kayit-ekrani hakkinda-ekrani
BITMAP2LCD – TO USE THE PROGRAM
Program can be downloaded from http://bitmap2lcd.com/pages/en.html. Although it is a bit complicated contains many extra features. After you install the program on your computer, you can create pictures using the following steps.
BITMAP2LCD STEP-1
In this step first, choose File> View / create / select project folders by opening the window of project files where created that we define then the LCD Matrix> 128 x 64 option, select File> Load a bitmap or JPEG file by using the menu in MS Paint’ve created bitmap file open.
18F452-bitmap2lcd-1
BITMAP2LCD STEP-2
After opening picture Select a system font and size> Font Panel window, click on the button and we come to the screen. Then
BITMAP2LCD STEP-3
After finishing all operations Output> Generate table of constant hex table using the menu file We’re getting started. To create a table in the format we want Hex Output> Show / hide table data configurations are making changes on the menu. CCS C 0 × 00 format for the need to create a table in column 8.
18F452-bitmap2lcd-3
Configuration data from Table tab are making changes as follows.
18F452-bitmap2lcd-3_1
BITMAP2LCD STEP-4
Output> Generate table of constant after the program is creating the hex code. File & Encoder Manager window that appears in the code table and Doc file by clicking Save’re recording. Then you want the file saved CCS C header included in the program would copy the table or the file in the program are using the hex.
18F452-bitmap2lcd-4
PIC18F452 GLCD CCS C Menu Schematic
Circuit is designed as a stopwatch and recording circuit but known schools are opened not separate stopwatch and record some more time. At least this kind of picture menu in the slightest about how to create and use the experience gained though. On subsequent days, I hope that comes across with more advanced projects: D For the moment, the menu can navigate through the menu, you can open and active. Arrow keys to navigate through the menu, to run the code from the active menu, you can use the MENU button. But only in the About section of the site has advertised other parts blank for now: D
pic18f452-grafik-lcd-kronometre
stopwatch circuit Isis proteus simulation project’s source files and other ccs c
Publication date: 2009/09/28 Tags: ,
1 Comment “PIC18F452 Graphic LCD Menu CCS C stopwatch Project
