Hello Electronics lovers. After a long hiatus, I wanted to write something again. In this article, software-serial basis (soft SPI) and still other applications I wrote using the name for a project I would like to help. 16 × 16 matrix graphic display I share with you my work on the foundations of
I compiled using pic16F877 74HC595 recorder at a speed of 20Mhz with these applications through screening method to create visual graphics display basic circuit diagram of the ISIS software mikroC C and Hex code attached file is available.
We also aim to have you with visual examples to work in 24 × 24 graphic display
Proteus isis circuit 16X16 LED Matrix schematic
Proteus isis led applications and the Matrix code files:
Aytaç Dürgen
Published: 2010/11/20 Tags: microchip projects, microcontroller projects, pic16f877 projects
Transistor BD137 is used Temperature Sensor Fan Control Circuit
In general, the LM35 temperature sensor in the control circuits, integrated dsxx series used in this application BD137 NPN transistor used as a sensor control circuit project fully regulated by a fan skies, has a printed circuit.
The files has the password to open, could you provide the next steps on accessing the file?
Hi, pass: 320volt.com
Thanks for the pass, It can display limited letters, could you provide the hex values for all the letters [from a-z and A-Z]
