12V 7A Rectifier Filter Circuits
| Updated on July 9, 2023
The circuit board the power supply consists of a Bridge Rectifiers with downstream E Capacitors. The input AC voltage is 1 and KL on the 6.3-mm plug ST 1 and ST 2. The diode D 1 D 4 to form the bridge rectifier. The low voltage of the river This money Schottky diodes reduced the power loss compared to a silicon diode around half creating a continuous current of up to 7 A is possible. Of course, the diodes in this current chilled, but enough already a small aluminum angle out.
POWER SUPPLY BOARD
Netzteil-power-supply-regler
The parallel to the diode-connected Capacitors C 1 to C 4 is intended to Interference suppression. With the two E Capacitors C 5 and C 6, the parallel Smoothed voltage (buffered). C5,C6 4700uf
12v_7_amper_dogrultucu
Source: http://www.elv-downloads.de/service/manuals/V42N/65860_Netzteil_V42N_km.pdf 12 Volt 7 Amp Rectifier Filter Circuits alternative link:
Publication date: 2008/06/28 Tags:
1 Comment “12V 7A Rectifier Filter Circuits
    12V 500ma Switch Mode Power Supply Circuit VIPer12A
    A SMPS viper12 a quality control sample for the use of integrated LED lighting can be used in different applications or .. have a nice design sizes quite small
    DC output: 12 mA VDC/500
    Efficiency: 75% typical
    Input voltage: 90-264VAC 50-60 Hz
    Dimensions: 57 x 49 x 32 mm
