Adjustable Power Supply Circuits Archive
| Updated on July 2, 2023
In our workshop, to run various circuits, or battery, battery charger that you can use in projects 0.x 0:30 volt power supply circuit that contains a variety of amps I’ve prepared a package. In addition to the professional power supply circuit includes a simple low-power designs.
Circuit in the voltage range of 0.30 volts forces 0.2.5 amps 12:10 amps 10 amp circuits having a little complicated and the cost is high picture circuit a break I’ve done, but a small mistake results can not run error until you find it so much uğraştım afterwards have to pick arrived projects were left unfinished elements with more than be careful teardown
0 0 30 volts 2.5 Amps LM324, BD135, 2N3773
0 30 volts 0 3 Amps TL081, 2N3055
0 0 5 Amps 2N3055 30 volts, LM723, CA3140
0 30 volts 0 5 Amps TIP35C, BD441, 2N3053, BC639, BC547, BC640
0 30 volts 0 10 Amps LM741, LM723, BC557B, BC547B, BD646
0 30 volts 0 10 Amps LM358, CD4011, BC548, BC558, TIP142, 2N3019
30-volt-current-voltage-regulated-power-supply-circuits
Adjustable Power Supply Circuits Archive download:
Publication date: 2008/01/13 Tags: , ,
2 Comments “Adjustable Power Supply Circuits Archive
    100 Watt Hifi Amplifier Circuit and 5-Band Equalizer
    Although a bit complicated PCBs in the circuit diagram drawing made ​​easy thanks to an amplifier circuit. Quite elegant in a printed circuit board component layout design very elegant addition to solid volume control located equalizer in the frequency range 15kHz, 50Hz, 250Hz, 1kHz, 4kHz,
    Output power transistors metal-sheathed (to3) transistors forces quite high during installation transistors isolator to isolate Note amp circuit power supply + – symmetric 35 volts DC equalizer circuit the + – 15 volts DC is working with this circuit to run an additional supply can or amp from the power supply can regulate with integrated regulator 7815 7915
    100 Watt Amplifier Circuit Diagram
    In unserer Werkstatt habe ich ein Paket vorbereitet, um verschiedene Stromkreise oder Akkuladegeräte zu betreiben, die Sie in Projekten mit einer 0: x 0: 30-Volt-Stromversorgungsschaltung verwenden können, die eine Vielzahl von Verstärkern enthält. Neben der professionellen Stromversorgung beinhaltet die Schaltung einen einfachen stromsparenden Aufbau.
    Schaltung im Spannungsbereich von 0,30 Volt Kräfte 0,2,5 Ampere 12:10 Ampere 10 Ampere Schaltungen mit ein wenig kompliziert und die Kosten sind hoch Bildschaltung eine Pause, die ich getan habe, aber ein kleiner Fehler führt nicht zu Fehlern, bis Sie finden Es ist so viel uğraştım danach angekommene Projekte zu holen, wurden unfertige Elemente mit mehr als vorsichtig Abriss gelassen
