Ne yazıkki detaylı açıklama yok untitled.bas yazılımında şifrenin 1111 olduğunu gördüm (satır 43) hata için alarm göstergesi var (led) 1 adet çıkışı var (röle) projede pic16f628 kullanılmış bu denetleyicinin maliyeti düşük ve buyutlarıda küçük. Emeği geçen Kişilere ve 67proje ekibine Teşekkürler
PIC16F628 şifreli kilit Devre Şeması
Untitled.bas
'**************************************************************** '* Name : UNTITLED.BAS * '* Author : [select VIEW...EDITOR OPTIONS] * '* Notice : Copyright (c) 2006 [select VIEW...EDITOR OPTIONS] * '* : All Rights Reserved * '* Date : 13.03.2006 * '* Version : 1.0 * '* Notes : * '* : * '**************************************************************** CMCON=7 TRISA=$1F TRISB=$00 PORTA=00 PORTB=00 ALARM VAR PORTB.0 KAPI VAR PORTB.1 SIFRE VAR WORD SIFRE1 VAR WORD SIFRE2 VAR WORD SIFRE3 VAR WORD SURE VAR WORD KUL VAR BYTE ADR VAR BYTE FLAGS=0 DEFINE LCD_DREG PORTB DEFINE LCD_DBIT 4 DEFINE LCD_RSREG PORTB DEFINE LCD_RSBIT 2 DEFINE LCD_EREG PORTB DEFINE LCD_EBIT 3 DEFINE LCD_LINES 2 DEFINE LCD_COMMANBUS 2000 DEFINE LCD_DATAUS 50 PAUSE 100 ENBAS: READ 02,SIFRE.BYTE0 READ 03,SIFRE.BYTE1 IF SIFRE=>65000 THEN SIFRE=11111 ADR=02 DEG: WRITE ADR,SIFRE.BYTE0 ADR=ADR+1 WRITE ADR,SIFRE.BYTE1 ADR=ADR+1 IF ADR=>20 THEN ENBAS1 GOTO DEG ENDIF ENBAS1: SIFRE=00 LCDOUT $FE,1,"SIFRE GIRINIZ" ENBAS2: LCDOUT $FE,$C0,"SIFRE=",#SIFRE," ONAY" ENBAS3: IF PORTA>00 THEN ENBAS3 ENBAS4: IF PORTA=00 THEN ENBAS4 IF PORTA=11 THEN BASLA IF PORTA=12 THEN SIFRE=00 : GOTO ENBAS2 IF SIFRE=>6500 THEN SIFRE=00 : GOTO ENBAS2 SIFRE=SIFRE*10 IF PORTA=10 THEN ENBAS2 SIFRE=SIFRE+PORTA GOTO ENBAS2 BASLA: LCDOUT $FE,1,"KULLANICI NO:" LCDOUT $FE,$C0,"YAZIMIZ" BASLA1: IF PORTA>00 THEN BASLA1 BASLA2: IF PORTA=00 THEN BASLA2 KUL=PORTA ADR=PORTA*2 READ ADR,SIFRE1.BYTE0 ADR=ADR+1 READ ADR,SIFRE1.BYTE1 IF SIFRE=SIFRE1 THEN LCDOUT $FE,1,"KAPI AC-KAPA=> 1" LCDOUT $FE,$C0,"SIFRE DEGIS => 2" GOTO KOMUT ENDIF ALARM=1 GOTO ENBAS KOMUT: IF PORTA>00 THEN KOMUT KOMUT1: IF PORTA=00 THEN KOMUT1 IF PORTA=01 THEN ALARM=0 TOGGLE KAPI GOTO ENBAS ENDIF IF PORTA=02 THEN SIFRED GOTO KOMUT SIFRED: ALARM=0 SIFRE=00 SIFRED1: LCDOUT $FE,1,"YENI SIFRE GIR" SIFRED2: LCDOUT $FE,$C0,"SIFRE=",#SIFRE," ONAY" SIFRED3: IF PORTA>00 THEN SIFRED3 SIFRED4: IF PORTA=00 THEN SIFRED4 IF PORTA=11 THEN SIFK IF PORTA=12 THEN SIFRE3=00 : GOTO SIFRED2 IF PORTA=>11 THEN SIFRED3 IF SIFRE=>6500 THEN SIFRE=00 : GOTO SIFRED2 SIFRE=SIFRE*10 IF PORTA=10 THEN SIFRED2 SIFRE=SIFRE+PORTA GOTO SIFRED2 SIFK: ADR=KUL*2 WRITE ADR,SIFRE.BYTE0 ADR=ADR+1 WRITE ADR,SIFRE.BYTE1 GOTO ENBAS
pic16f628-lcd-display-gostergeli-sifreli-kapi-kilit-projesi
Ne yazikki zip dosyasının icinde .bas dosyası yok bilginize
sifreyi kullanamadim
Diyot olarak ne kullanıyoruz
1n4148 kullanabilirsiniz
sağ olun bende bunu arıyordum
ama kullanıcı kodunu bulamadım hala
meraba ben 5 tane 1 giriyorum şifreye sonra onaya basıyorum sonra kullanıcı no cıkıyor ama onu bulamıyorum yardımcı olurmusunuz kullanıcı kodu kaç?
Hazır tuş takımı alırsan pic16f628a da 12 tuşlu bir hazır tuş takımını bağlayacak port bulamazsın çünkü böyle bir takımdan 7 uç çıkar. Arkadaşın yaptığı sistemde 4 uçla işi halletmiş.
Şifre: 11111 Kullanıcı No: 2 dir. Benim merak ettiğim devrede yapan arkadaş tuş takımını kendisi tasarlamış butonlarla. Onun yerine hazır yapılmış tuş takımları var. Hazır tuş takımı alsak nasıl bağlayabiliriz devreye ?
Peki arkadaşlar, kilit kısmı nasıl olacak? Herşey tamam sifre dogru ve röle aktif oldu. Kilidi cekecek manyetik sistem nasıl olacak? Bilgisi olanlardan bir yardım. Teşekkürler
pcb yok paylaşmanız mümkünmü acaba
