Epson S1D15G14 entegresini kullanan Nokia 3510i grafik lcd kullanımı için hazırlanmış bir devre projenin yazılımı Hi-tech C ile hazırlanmış mikro denetleyici ise pic16f628.
This example shows how the Nokia 3510i color LCD can be interfaced and driven using the PIC16F628 microcontroller. The code is written in Hi-Tech C.The Nokia LCD has 96×65 pixels. Software : This project uses Hi-Tech C compiler available from www.htsoft.com . I used Ic-prog to program the 16F628 using the ProPic-2 Programmer
colorlcd.c içeriği
//_______________________________________________________________________________________________________ // PIC to Nokia color LCD (type Epson S1D15G14) driving routines written Hi-Tech C // written by Ramandeep Singh ©2004 // www.spiralbrain.tk or http://67.15.78.55/~spiral/ // [email protected] // Date: 21 Nov 2004 // main file. // //_______________________________________________________________________________________________________ #include "pic.h" #include "delay.h" #include "delay.c" __CONFIG(0x3f10); void send(unsigned char data, unsigned char cd); void cs(void); #define SCLK RB0 #define SDATA RB1 #define CS RB2 #define RESET RB3 #define CMD 0 #define DATA 1 unsigned char c; void main(void) { unsigned int i; unsigned char s,a; TRISB = 0x00; // portB is output; (NOKIA LCD = portB) TRISA = 0x00; CMCON = 0b00000111; // disable comparators PORTB = 0x00; // all low PORTA = 0x00; DelayMs(250); // LCD Hardware Reset RESET=0; DelayMs(5); RESET=1; CS=1; SCLK=1; SDATA=1; send(0x01, CMD); // LCD Software Reset cs(); DelayMs(5); send(0xC6, CMD); // Initial Escape cs(); send(0xB9, CMD); // Refresh set send(0x00, DATA); cs(); send(0xB6, CMD); // Display Control send(128, DATA); send(128, DATA); send(129, DATA); send(84, DATA); send(69, DATA); send(82, DATA); send(67, DATA); cs(); send(0xB3, CMD); // Gray Scale Position send(1, DATA); send(2, DATA); send(4, DATA); send(8, DATA); send(16, DATA); send(30, DATA); send(40, DATA); send(50, DATA); send(60, DATA); send(70, DATA); send(80, DATA); send(90, DATA); send(100, DATA); send(110, DATA); send(127, DATA); cs(); send(0xB5, CMD); // Gamma Curve Set send(1, DATA); cs(); send(0xBE, CMD); // Power Control send(4, DATA); cs(); send(0x11, CMD); // Sleep out cs(); send(0xB7, CMD); // Temperature gradient set for(i=0; i<14; i++) { send(0, DATA); } cs(); send(0x03, CMD); // Booster Voltage ON cs(); DelayMs(40); send(0x20, CMD); // Inversion control cs(); send(0x25, CMD); // Write contrast send(75, DATA); //was 63 cs(); send(0x29, CMD); // Display On cs(); send(0x2C, CMD); // Memory Write for(a=0;a<4;a++) { s=0; for(i=0; i<294; i++) { if(s == 0) send(15, DATA); // 15 else if(s == 1) send(240, DATA); // 240 else if(s == 2) send(255, DATA); // 255 if(++s == 3) s = 0; } s=0; for(i=0; i<294; i++) { if(s == 0) send(240, DATA); else if(s == 1) send(255, DATA); else if(s == 2) send(15, DATA); if(++s == 3) s = 0; } s=0; for(i=0; i<294; i++) { if(s == 0) send(255, DATA); else if(s == 1) send(15, DATA); else if(s == 2) send(240, DATA); if(++s == 3) s = 0; } s=0; for(i=0; i<294; i++) { if(s == 0) send(0, DATA); else if(s == 1) send(240, DATA); else if(s == 2) send(15, DATA); if(++s == 3) s = 0; } s=0; for(i=0; i<294; i++) { if(s == 0) send(15, DATA); else if(s == 1) send(0, DATA); else if(s == 2) send(240, DATA); if(++s == 3) s = 0; } s=0; for(i=0; i<294; i++) { if(s == 0) send(240, DATA); else if(s == 1) send(15, DATA); else if(s == 2) send(0, DATA); if(++s == 3) s = 0; } for(i=0; i<294; i++) { send(0, DATA); } for(i=0; i<294; i++) { send(255, DATA); } cs(); } send(0x29, CMD); // Display On cs(); while(1) { send(0x21, CMD); // Initial Escape cs(); DelayMs(250); DelayMs(250); send(0x20, CMD); // Initial Escape cs(); DelayMs(250); DelayMs(250); } } void send(unsigned char data, unsigned char cd) { CS=0; SCLK=0; if(cd == CMD) SDATA=0; else SDATA=1; SCLK=1; for (c=8;c>0;c--) { SCLK=0; if ((data&0x80)==0){ SDATA=0; } else { SDATA=1; } SCLK=1; data=data<<1; } } void cs(void) { CS=1; // CS = 1 }
Kaynak: sunbizhosting.com/~spiral/colorlcd/ (kapalı)
nokia-3510i-lcd-s1d15g14-arayuz-hitech-pic16f628
Yayım tarihi: 2009/10/16 Etiketler: 3510 hitech, grafik lcd, hitech c, microchip pic projeleri, nokia 3510i lcd, PIC16F628 örnekleri, s1d15g14
