Signal generator Circuit PIC16F88 JAL Code Example
| Updated on May 6, 2016
In an experiment with some changes I use this circuit for the development of’m sending you. I could not work because it is not a final time.
To put it in principle, be controlled by Pic-5V to +5 V analog switch between the output stage is based on the principle of giving. The future with analogue switch (CD4051) 4 units of work for removing a circuit will do better.
Would be best to send with the finished but at the moment I do not have time for this study. The reason for using 16F88 is for adjusting the frequency. Found another pic of the ADC can be used. ADC will connect the potentiometers with a frequency can be adjusted. I try to help to develop friends. Jal the spline drawing software.
Wishing to be useful and good work.
Signal generator Circuit Schemmatic
sinyal-Jenerator-devresi-150x150
Jal source code
include 16f88_4i
include jlib
port_b_direction = all_output
var byte x
x = 1
procedure sinyal is
port_b = 0b0100_0001  -- 1
delay_10us(x)
port_b = 0b0100_0010 --   2
delay_10us(x)
port_b = 0b0100_0011
delay_10us(x)          -- 3
port_b = 0b0100_0100   --  4
delay_10us(x)
port_b = 0b0100_0101   --  5
delay_10us(x)
port_b = 0b0100_0110    --  6
delay_10us(x)
port_b = 0b0100_0111   --   7
delay_10us(x)
port_b = 0b0100_0110     --  8
delay_10us(x)
port_b = 0b0100_0101    --   9
delay_10us(x)
port_b = 0b0100_0100  --  10
delay_10us(x)
port_b = 0b0100_0011     --  11
delay_10us(x)
port_b = 0b0100_0011       -- 12
delay_10us(x)
port_b = 0b0100_0000       -- 13
delay_10us(x)
port_b = 0b0000_1000       --  14
delay_10us(x)
port_b = 0b0001_0000      -- 15
delay_10us(x)
port_b = 0b0001_1000      --  16
delay_10us(x)
port_b = 0b0010_0000      --  17
delay_10us(x)
port_b = 0b0010_1000       --  18
delay_10us(x)
port_b = 0b0011_0000        --  19
delay_10us(x)
port_b = 0b0011_1000        --  20
delay_10us(x)
port_b = 0b0011_0000        --  21
delay_10us(x)
port_b = 0b0010_1000       --  22
delay_10us(x)
port_b = 0b0001_1000       -- 23
delay_10us(x)
port_b = 0b0001_0000       --  24
delay_10us(x)
port_b = 0b0000_1000       --  25
delay_10us(x)
port_b = 0b0000_0000       --  26
delay_10us(x)
end procedure
forever loop
sinyal
end loop
Publication date: 2010/02/07 Tags: , ,
1 Comment “Signal generator Circuit PIC16F88 JAL Code Example
    PIC16F877 ADC Volt Meter Circuit MicroC Example
    In this work, using a PIC16F877 Hello friends and I created a volt meter with single-channel ADCs have. Similar programs for use with the volt meter microcar able to find the opportunity to examine what I thought. At a later time, I will publish the project again in a state of functional
