Disco Light Effects System with PIC16F876
| Updated on August 4, 2019
It is a circuit for the circuit only show animation, colored lights and sound in proportion to the severity of a circuit to change the animation speed, also have created this. Usually known as disco effects, disco lights, etc..
Mounted to the surface in the form of a circle of colorful glass circuit stepper motor on the wall thanks to the lens color images that leading utility was and is being created.
The purpose of the circuit according to the change of pace that this stepper motor environment sound and animation.
The Disco Effect System Proteus Isis Circuit Diagram;
disco-lamp-disko-lamba-lamba-efekt
Circuit diagram for display prior to a pre amplifier to amplify the voice of the RV1 trimpot and the integration of audio amplifier of amplifier was added to replace TDA2822 Ile Yapılmış RV1 adjustable resistor potentiometer in the circuit box, these were mounted and sound sensitivity potentiometer setting.
pic16f876-disko-isik-efekt-sistemi-disco-lights
In front of the lens as seen in the picture below stepper motor on the circuit after placement was done by connecting a potentiometer knob installed in the box instead’ve prepared with pieces of colored glass in the picture color and placement of the apparatus is not well
disco-lamp-disko-lamba-lamba-efekt-pic16f876-disco-lights
Disco Effect System proteus isis scheme of the project, ares pcb and software files:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-22788.zip
Publication date: 2014/03/06 Tags: , ,
2 Comments “Disco Light Effects System with PIC16F876
    Iron Base With Preheating Machine
    I have added to my list of useful, a lot of my work is a system to facilitate the “Preheating Machine” author told that more quickly by pressing the PCB the PCB with the ironing pressure using make, but can be used in so many different things depending on the situation, for example, repair work, especially for PC, laptop, etc. without removing the main cards parts before disassembling the front heating can be achieved more easily with parts or soften the pressed boxes etc..
    Disco Lichteffekt Systems mit PIC16F876
    Es ist eine Schaltung für die Schaltung nur zeigen, animation, bunten Lichtern und sound-im Verhältnis zu der schwere der Schaltung ändern, um die animation Geschwindigkeit, auch haben dies. In der Regel bekannt als disco-Effekte, disco-Lichter, etc..
