Sony Philips RC5 IR Remote Decoder Circuit PIC16F84A
| Updated on July 15, 2023
Sony and Philips RC5 protocol that works with the remote control of the code to learn a useful circuit on the circuit porta.3 pin 1 if sony 0 no RC5 philips decode the received 16-bit data of the 8-bit device code other 8-bit the read key is the value of various control with tried circuit is fine works beautifully. Codes were written with protons. Proton ide ready to read IR commands are used.
Remote Decoder Work Images
sony-rc5-kumanda-kod-okuma-2 sony-rc5-kumanda-kod-okuma-3
sony-rc5-kumanda-kod-okuma-4 sony-rc5-kumanda-kod-okuma-5
PIC16F84A Remote Decoder Schmeatic
sony-pic16f84a-proton-150x150
PIC16F84A Remote Decoder proton ide source code files:
Publication date: 2009/01/15 Tags: , ,
1 Comment “Sony Philips RC5 IR Remote Decoder Circuit PIC16F84A
    VU Meter Circuits LM3914 LM3915 PCB
    VU Meter circuit has 2 versions of the LM3914 and made ​​with lm3915.. LM3914 Dot Bar Display Driver LM3914 is a monolithic integrated circuit that senses analog voltage levels and drives 20 Led stereo Vu Metre Devresi PCB Circuit LM3914 10 leds stereo vumeter circuit diagram of Eagle PCB drawing of eagle
    VU Meter Circuits
