3x3x3 LED Cube with PIC16F628 microcontroller circuit
| Updated on August 4, 2019
The market plenty of 4 x 4 x 4 led cube was made. I have made 3 x 3 x 3 led cube we also differ. Led cube in each layer is made up of 3 × 3 cut into 3 layers 9 ledden and 27 LEDs.
Led Cube circuit software and new animations. Each floor minus the ends of the pressure circuit, K1, K2, and K3 connect the writer places. the first layer on a printed circuit board connected to the tip of the pressure circuit, K1, . Printed circuit board on the 7805 5V regulator IC there if you want to use this version of the circuit with the input voltage must be at least 8v 12 can be used if you have a 5v regulated supply already voltda if there is no need to use 7805. If you are interested in and the Led cube circuits is less with this project will be useful to start your experience.
led-cube-circuit-led-kupu-yapimi-led-kup-yapimi-led-kup-nasil-yapilir-led-kup-devres
led-cube-circuit-led-kupu-yapimi-proteus-isis-pic16f628
All the files necessary for the construction of the Led Cube (proteus isis, ares, and the source code)
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-22708.zip
Publication date: 2014/02/22 Tags: , , ,
2 Comments “3x3x3 LED Cube with PIC16F628 microcontroller circuit
    Guitar Tuning Project with Arduino Uno
    Arduino Uno kit on the Board at the entrance of the TL082 opamp used Guitar Tuning circuit audio audio input and frequency to detect the “Arduino-Frequency-Detection” software used.
    According to the LEDs light at certain frequencies sesisnin the guitar.
    E – 82.4 Hz
    A – 110Hz
    D – 146.8 Hz
    G – 196Hz
    B – 246.9 Hz
    E – 329.6 Hz
    LED-Würfel mit PIC16F628 microcontroller circuit
    Der Markt viel 4 x 4 x 4-led-cube gemacht wurde. Ich habe aus 3 x 3 x 3 led-Würfel wir auch Verschieden. LED-Würfel in jede Ebene besteht aus 3 × 3 schneiden in 3 Ebenen ledden 9 und 27 LEDs.
    LED-Würfel-Schaltung, software und neue Animationen. Jede Etage minus die enden der Druck-Schaltung, K1, K2 und K3 verbinden Sie den Autor stellen. die erste Schicht, die auf eine gedruckte Leiterplatte angeschlossen, auf der Spitze des Druck-Schaltung
