Industrial Fan driver circuit
| Updated on August 4, 2019
Designed for the control of the fan motors used for cooling purposes. 4A 24V DC motor with soft start cooling fan is driven with the control card has made; and supply of other system components and is intended to avoid sudden loading peaks. The thermostat with the control card to be connected to the ignition system is being taken up.
fan-kontrol-lm7810-irf4905-byw80-200-lm358-pc817
endustriyel-fan-surucu-fan-kontrol-devresi-fan-speed
fan_PCB_Connection
Such during the time that is set with P1, the DC motor accelerated and operated at full load. Input voltage, such a set value, the thermostat and ignition voltages of the three motor status can be read from the test points on the card. Control card at the entrance transil diode, varistor, ferrite coils and using the parasitic potential formation is prevented. Scratches copied from the PCB Control Card schematic card of foreign origin is intended.
Proteus Ares PCB drawing files Industrial Fan driver circuit and the PFD source:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-25446.zip
Publication date: 2016/04/22 Tags:
2 Comments “Industrial Fan driver circuit
    AV800 Amplifier Project 500W 1000W
    AV800 Amp Forum application @fatih_celebi24 my brother have been sharing it sharing be noted that the following description has been a long time thanks for sharing it @fatih_celebi24
    Hello, I tried to draw a long time ago AV800 Amp just as a hobby I decided to post my circuit made and were tested.
    N-Channel 5 A P-channel mosfet 5 mosfet was used to drive a solid 10, It is able to provide a feed.
    The solid floor is drawn in a format that can fit A4 power power supply 100V capacitor 10000mf stop. Supply Voltage +\- max. 90V kind. recommended +\- 60V AC. ideal +\- 75vdc like you can use.
    Industrielle Ventilator-Treiber-Schaltung
    Konzipiert für die Steuerung der Ventilator-Motoren zu kühlzwecken verwendet. 4A 24V DC-motor mit soft-start Kühlung Ventilator angetrieben wird, der mit der Kontrollkarte gemacht hat; und die Lieferung von anderen system-Komponenten und soll vermeiden Sie plötzliche Belastung Gipfel. Der thermostat mit der control card angeschlossen werden, um die Zündung genommen wird.
