DC DC Konvertör devresi 3.6 Li-Ion pil voltajını 5 volta yükseltiyor fazla detaylı bir devre değil ATtiny15 mikrodenetleyici ile güç kontrolü için güzel bir örnek yazılım assembly dili ile hazırlanmış
main.asm kod içeriği;
;################################### ;# # ;# step-up voltage regulator Li-Ion -> 5V with shutdown # ;# version 0.10 # ;# copyright (c) 2008 Joerg Wolfram ([email protected]) # ;# # ;# # ;# This program is free software; you can redistribute it and/or # ;# modify it under the terms of the GNU General Public License # ;# as published by the Free Software Foundation; either version 2 # ;# of the License, or (at your option) any later version. # ;# # ;# This program is distributed in the hope that it will be useful, # ;# but WITHOUT ANY WARRANTY; without even the implied warranty of # ;# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.See the GNU # ;# General Public License for more details. # ;# # ;# You should have received a copy of the GNU General Public # ;# License along with this library; if not, write to the # ;# Free Software Foundation, Inc., 59 Temple Place - Suite 330, # ;# Boston, MA 02111-1307, USA. # ;# # ;#################################### ;----------------------------------- ;ATTiny15: ; 1 - RESET ; 2 - UB/2 ; 3 - UA/3 ; 4 - GND ; 5 - /SHUTDOWN ; 6 - output - PWM ; 7 - output - /Enable ; 8 - UBatt ;--------------------------------- .include "tn15def.inc" .equ v_reg = 167 ;target voltage * 33.33 .equ v_sdown = 150 ;shutdown voltage * 50 .equ max_pwm = 230 ;PWM maximum .equ min_pwm = 4 ;PWM minimum .org 0x000 init: ldi r26,0x61 ;PWM out TCCR1,r26 ;set ldi r26,0xff ;max out OCR1B,r26 ; ldi r27,0x10 ;6% PWM at start out OCR1A,r27 ;set PWM value ldi r26,0x00 out MCUCR,r26 ;enable pullups ldi r26,0x01 ;set values out PORTB,r26 ldi r26,0x06 ;PB1-2 as output out DDRB,r26 ;set ldi ZL,LOW(1500) ;reset shutdown counter ldi ZH,HIGH(1500) phase1: ldi r20,0x00 ;phase 1 (startup) phase1_1: rcall get_adc ;dummy conversions dec r20 ;loop counter brne phase1_1 ;wait clt ;clear shutdown flag rcall get_adc ;get adc values rcall check_ub ;check UB for low voltage shutdown brtc phase2 ;OK->phase 2 rjmp shutdown phase2: ldi r20,0x00 ;phase 2 (setup voltage) phase2_1: rcall get_adc ;get ADC values rcall calc_pwm ;regulation out OCR1A,r27 ;set PWM value dec r20 ;loop counter brne phase2_1 ;loop loop: rcall get_adc ;get voltages rcall calc_pwm ;regulation out OCR1A,r27 ;set PWM value rcall check_ub ;check UB for low voltage shutdown rcall check_sp ;check shutdown pin brtc loop ;loop if OK shutdown: clr r26 out TCCR1,r26 ;disable timer out OCR1A,r26 ; ldi r26,0x04 out PORTB,r26 ;disable ldi r26,0x70 out MCUCR,r26 ;set sleep mode to powerdown sleep sd1: rjmp shutdown ;only for safety ;------------------------------------------ ; get ADC values ; PIN 2 (UB) in r24 ; PIN 3 (UA) in r22 ;----------------------------------------- get_adc: ldi r26,0xa2 ;set channel out ADMUX,r26 ; ldi r26,0xc4 ;start conversion out ADCSR,r26 ; get_adc_1: sbic ADCSR,6 ;skip if complete rjmp get_adc_1 ;wait in r16,ADCH ;get ua ldi r26,0xa3 ;set channel out ADMUX,r26 ; ldi r26,0xc4 ;start conversion out ADCSR,r26 ; ;calc damped value (1/1) add r22,r16 ; ror r22 get_adc_2: sbic ADCSR,6 ;skip if complete rjmp get_adc_2 ;wait in r16,ADCH ;get UB ;calc damped value (1/1) add r24,r16 ror r24 ret ;----------------------------------------- ; calc new PWM value ;----------------------------------------- calc_pwm: cpi r22,v_reg ;target voltage brcc calc_pwm_2 ;is greater inc r27 ;PWM + cpi r27,max_pwm ;upper PWM limit brcs calc_pwm_1 ;less dec r27 ;PWM - subi r28,1 ;shutdown counter sbci r29,0 ; brcc calc_pwm_1 ;branch if no overload set ;set shutdown flag calc_pwm_1: ret calc_pwm_2: ldi r28,LOW(1500) ;re-set counter ldi r29,HIGH(1500) cpi r22,v_reg ;target voltage brcs calc_pwm_3 ;is less dec r27 ;PWM - cpi r27,min_pwm ;minimum brcc calc_pwm_3 ;branch if not reached inc r27 ;PWM + calc_pwm_3: ret ;-------------------------------------------- ; check undervoltage ;-------------------------------------------- check_ub: cpi r24,v_sdown ;3V min brcc check_ub_1 ;greater set ;set shutdown flag check_ub_1: ret ;thats all ;------------------------------------------- ; check shutdown pin ;------------------------------------------ check_sp: sbic PINB,0 ;skip if active rjmp check_sp_2 ; subi ZL,1 ;counter -1 sbci ZH,0 brcc check_sp_1 set ;set shutdown flag check_sp_1: ret ;thats all check_sp_2: ldi ZL,LOW(750) ;re-set counter ldi ZH,HIGH(750) ret
Hazırlayan: Joerg Wolfram
attiny15-ile-dc-dc-konvetor-ornegi-3-6v-5v-assembly
Yayım tarihi: 2010/11/28 Etiketler: atmel avr projeleri, attiny15, dc dc dönüştürücü devreleri, dc dc konvertor, dcdc
