Thermometer Hygrometer Circuit USB DHT22 ATmega8
| Updated on August 4, 2019
The presented layout is a snap on a computer for measuring DHT22 temperature and humidity. It measures the temperature from -40 to 80 ° C with a resolution of 0.1 ° C and accuracy of 0.2 ° C and humidity from 0 to 100% with a resolution of 0.1% and accuracy of 2%. The device was designed on a tiny size plate with the advantage of surface mount elements, so it can be used as a laptop or desktop adapter. The microcontroller control program was written in the Bascom AVR environment. The DHT22 sensor temperature and humidity reading
DHT22 Thermometer Hygrometer Circuit schematic
dht22-thermometer-hygrometer-circuit-schematic
The schematic diagram of the thermometer Its “heart” is the ATmega8 microcontroller operating with an external 7.3728 MHz quartz resonator. The clock frequency was chosen so that the transmission error of the UART system was 0%.
The project uses the ATmega8 microcontroller in the smd TQFP32 housing and the FT232 chip in the SSOP28 enclosure, which, due to the raster patches, needs to be mounted on the rack. After soldering the microcontroller and the FT232 system, solder all jumper and serial components in order from smallest to largest.
dht22-thermometer-hygrometer-microcontroller-projects
usb-term-avr-project-atmega8-projects
usb-program-dht22-thermometer-hygrometer-1
usb-program-dht22-thermometer-hygrometer-2
srcb2
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-25807.zip
Publication date: 2017/10/01 Tags: , ,
1 Comment “Thermometer Hygrometer Circuit USB DHT22 ATmega8
    Wärmemesser Schaltung USB DHT22 ATmega8
    Das vorgestellte Layout ist ein Schnappschuss auf einem Computer zur Messung von DHT22 Temperatur und Luftfeuchtigkeit. Es misst die Temperatur von -40 bis 80 ° C mit einer Auflösung von 0,1 ° C und einer Genauigkeit von 0,2 ° C und einer Luftfeuchtigkeit von 0 bis 100% mit einer Auflösung von 0,1% und einer Genauigkeit von 2%. Das Gerät wurde auf einer winzigen Platte mit dem Vorteil von Oberflächenmontageelementen entwickelt, so dass es als Laptop- oder Desktop-Adapter verwendet werden kann. Das Mikrocontroller-Steuerungsprogramm wurde in der Bascom AVR-Umgebung geschrieben. Die Temperatur- und Feuchtigkeitsmessung des DHT22-Sensors
    DHT22 Thermometer Hygrometer Schaltplan
