Zamanında çok popüler olan Electronic Workbench programının yeni hali Multisim programı (v10) ile hazırlanmış 135 adet temel elektronik devresi özellikle sunumlarda, bazı devreleri çözmek için oldukca faydalı olacak çalışmalar var tüm devrelerde belirli noktalara ölçüm araçları yerleştirilmiş araçlara çift tıklayarak sinyal, frekans vb. gibi bilgiler simülasyon ortamında gözlemlenebiliyor.
Multisim RLC Circuits
004 Parallel DC Circuits.ms10
005 Series-Parrallel DC Circuit.ms10
006 Current Analysis.ms10
007 Millmans Theorem 1.ms10
008 Millmans Theorem 2.ms10
009 Kirchhoff’s Current Law.ms10
010 Thevenin’s Theorem.ms10
011 Superposition Principle.ms10
012 Nortons Theorem and Source Conversion.ms10
013 AC Voltage Measurement.ms10
014 Frequency Response of the Series RL Network.m
015 RL High and Low Pass Filter.ms10
016 Frequency Response of the Series RC Network.m
017 RC High and Low Pass Filter.ms10
Multisim Diodes
019 Center-Tapped Full-Wave Rectifier.ms10
020 Bridge Rectifier.ms10
021 Capacitor-Input Rectifier Filter.ms10
022 Diode Clipper (Limiter).ms10
023 Diode Clipper.ms10
024 Diode Clamper (DC Restorer).ms10
025 Diode Voltage Doubler.ms10
026 Zener Diode and Voltage Regulation 1.ms10
027 Zener Diode and Voltage Regulation 2.ms10
028 Zener Diode and Voltage Regulation 3.ms10
Multisim Transistors
030 NPN Transistor with Emitter Bias.ms10
031 PNP Transistor with Voltage-Divider Bias.ms10
032 NPN Operating Point.ms10
033 Base-Biased Transistor.ms10
Multisim Amplifiers
034 Class B Push-Pull E-F Amplifier.ms10
035 Class B Push-Pull E-F Amplifier.ms10
036 Class A Power Amplifier.ms10
037 Darlington Pair.ms10
038 Combination Common-Emitter Amplifier and Emit
039 Collector Feedback Amplifier.ms10
040 Common-Emitter Amplifier with Source Resistan
041 Common-Emitter Amplifier.ms10
042 Common-Base Amplifier.ms10
043 Common-Collector Amplifier.ms10
044-Two-Stage Common-Collector Amplifier.ms10
045 Two Stage Common Emitter Amplifier.ms10
046 Two-Stage Common-Base Amplifier.ms10
Multisim Opamps
047 Inverting Amplifier.ms10
048 Inverting Amplifier with AC Input Signal.ms10
049 Non-Inverting Amplifier.ms10
050 Non-Inverting Opamp Circuit.ms10
051 Opamp Comparator.ms10
052 Bounded Comparator.ms10
053 Double-Bounded Comparator.ms10
054 Window Detector.ms10
055 Schmitt Trigger.ms10
056 Nonzero_level Detector.ms10
056 Nonzero-level Detector.ms10
057 Inverting Positive-Voltage Detector.ms10
058 Positive-Voltage Detector.ms10
059 Inverting Adder.ms10
060 Non-Invering Adder.ms10
061 Opamp Differentiator.ms10
062 Basic Differential Amplifier.ms10
063 Opamp Common-Mode Rejection.ms10
064 Basic Differential Amplifier with Sensing Ter
065 Common_Mode Voltage Amplifier.ms10
065 Common-Mode Voltage Amplifier.ms10
066 Triangular-Wave Generator.ms10
067 Triangular-to-Sine-Wave Generator.ms10
068 Dead-Zone Circuit with Negative Output.ms10
069 Dead-Zone Circuit with Positive Output.ms10
070 Bipolar Dead-Zone Circuit.ms10
071 Peak Detector.ms10
072 Precision Clipper.ms10
073 Precision Full-Wave Rectifier.ms10
074 Basic Shunt Regulator.ms10
075 Basic Opamp Series Regulator.ms10
076 Short Circuit or Overload Pretection.ms10
077 Current-To-Voltage Converter.ms10
078 Voltage Follower.ms10
079 Digital-to-Analog Converter.ms10
080 Sevo Amplifier.ms10
081 Subtractor.ms10
083 Opamp Integrator.ms10
Multisim Filters
084 First Order Low-Pass Filter.ms10
085 Second-Order Low-Pass Filter.ms10
087 Sallen-Key Second-Order Low-Pass Filter.ms10
088 Third-Order Low-Pass Filter.ms10
089 High-Pass Active Filter.ms10
091 Second-Order High-Pass Filter.ms10
092 Butterworth Second-Order High-Pass Filter.ms1
093 Third-Order High-Pass Filter.ms10
095 Wideband Bandpass Filter.ms10
096 Speech Filter.ms10
097 Narrow Bandpass Filter.ms10
099 Active Bandpass Filter.ms10
101 Active Notch Filter.ms10
Multisim Miscellaneous Circuits
103 Shunt Feedback Circuit.ms10
105 TTL Inverter.ms10
107 TTL Gate.ms10
109 OR Gate Circuit.ms10
111 Over-Damp Circuit.ms10
113 Critical-Damp Circuit.ms10
115 Series RLC Circuit 1.ms10
117 Clapp Oscillator.ms10
119 Differential Amplifier 1.ms10
121 Differential Amplifier in Common Mode.ms10
123 LC Oscillator with Unity Gain Buffer.ms10
125 Notch Filter.ms10
127 PNP Differential Pair.ms10
129 Crossover Network.ms10
131 Second-Order High-Pass Chebyshev Filter.ms10
133 Third-Order High-Pass Chebyshev Filter.ms10
135 Fifth-Order High-Pass Filter.ms10
Yayım tarihi: 2012/02/11 Etiketler: devre simülasyonları, multisim, multisim 10, multisim circuits, multisim devreleri, simülasyon devreleri
yazı yayınlanalı çok zaman olmuştur heralde ama 1 sorum var
multisimde 1 diyodun karakteristiğini nasıl çıkarabiliriz?
osiloskop vs. kullanarak olabilir mi?
